Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 06-10-2018, 20:22   #361 (permalink)
Member: 748
Thanks Meter: 9
g950f 8.0
Just solved g950f 8.0
confirmed working
The Following User Says Thank You to roki For This Useful Post:
Old 06-11-2018, 22:03   #362 (permalink)
Alfareedmobile's Avatar
Member: 2675538
Thanks Meter: 90
Its working 1000% what you think about sc_02h s7 edge docomo japan frp solution ?
The Following User Says Thank You to Alfareedmobile For This Useful Post:
Old 06-12-2018, 12:12   #363 (permalink)
Member: 219420
Thanks Meter: 78
Originally Posted by frosted View Post
what if the enable OEM menu is not showing up
click on calculator and dial *#0808# select last option save and reboot
put download mode again flash yor phone using sboot+boot+catch+recovery+system file with z3x or octopus
thats it
Old 06-13-2018, 19:37   #364 (permalink)
Member: 49066
Thanks Meter: 5
combination file for G950W
Old 06-28-2018, 01:30   #365 (permalink)
Member: 2847161
Do I have to download all 3 combination links for SM-G950U?
Old 07-05-2018, 09:36   #366 (permalink)
BackOFF's Avatar
Member: 583290
Thanks Meter: 107
samsung g950f
G950FXXU1AQK7 7.0
which combination file is suitable for this rom to remove frp from z3x support collection.?
Old 07-05-2018, 16:40   #367 (permalink)
Member: 2425823
there´s a good combination file here my problem is firmware
Old 07-05-2018, 16:41   #368 (permalink)
Member: 2425823
any one have KSA firmware s8 7.0
Old 07-10-2018, 20:06   #369 (permalink)
Member: 2804632
Same, I dont have issues finding combination files for my G955U . I have issues finding the one for my Oreo firmware G955USQS3CRE2
I am going to try and flash an earlier firmware and use a combination file for that specific one.
If that's the route , which should I downgrade to? Currently at 8.0 and Which combination file would work with that specific firmware ?
I was thinking G955USQU1AQJ8 firmware and the SM-G955USQU1AQDA combination ...
Anyone have luck with that theory ? Any input ? Still new to flashing. Will post back results .
Thanks for writing this guide
Old 07-11-2018, 00:43   #370 (permalink)
maremestera's Avatar
Member: 691388
Thanks Meter: 371
do not downgrade from bit3 or u loose baseband. Keep searching for firmware on xda site
The Following User Says Thank You to maremestera For This Useful Post:
Old 07-11-2018, 01:07   #371 (permalink)
Member: 2713022
Thanks Meter: 3
For that firmware version, you need bit3
Download it here. it is free:
https://tx5.androidfilehost.com/dl/h...5USQU3ARD1.zip
The Following User Says Thank You to shawnmaine For This Useful Post:
Old 07-11-2018, 01:33   #372 (permalink)
Member: 2804632
maremestera, Thanks a bunch for heads up. Glad I didn't .
Awesome ! I've found bit1,2 and 4 . Could not find 3 for life of me .
Much appreciated bro
This is my first time using a combination file. Reading through this site and others, seems I can flash via Odin in AP slot ?
Old 07-11-2018, 03:23   #373 (permalink)
Member: 2804632
Aftering booting into combination file , going to settings and enabling " Unlock OEM " . ( In hope to bypass FRP ) It does not stay enabled .
I went ahead and flashed G955USQS3CRE2 back onto G955U in hopes the FRP Lock was off.
On ROM before I triggered FRP under development settings there was not a " OEM Unlock " present .
Device is SM-G955U, If the U is for " Unlocked" Would this phone not have it? How would I go about Bypassing FRP. I do have USB Debugging enabled.
Old 07-11-2018, 03:37   #374 (permalink)
Member: 2804632
You need to flash combination, after that flash from normal firmware only system+sboot+boot+recovery+cache.
I am using ODIN, So I flashed BL,AP and CSC from normal firmware and Made sure to leave out CP.
Booted to Samsung logo, an has boot loop for last 25 minutes
What did I miss? Should I not use Odin ? Or do I need to specifly pick system sboot boot recovery cache somehow?
Old 07-11-2018, 22:38   #375 (permalink)
Member: 691388
Thanks Meter: 371
make sure you use home_csc. After any fail, flash again combination, then do the rest of it
Page generated in 0.24320 seconds with 9 queries
