Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
07-27-2018, 08:33 | #391 (permalink) |
No Life Poster Join Date: Mar 2007 Location: Skopje, Macedonia Age: 36
Member: 472933 Status: Offline Sonork: 100.1590967 Thanks Meter: 1,331 | |
07-27-2018, 09:07 | #392 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Offline Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,109 | @ Boshko_Alfa Did you already tried this method? Also use the latest version of Odin3_v3.13.1 First flash factory firmware, after make hard reset by KEY, flash the latest version of combination file, hopefully this procedure will work for you. Example:- today I did ''S9+'' Code: <ID:0/030> Added!! <ID:0/030> Odin engine v(ID:3.1301).. <ID:0/030> File analysis.. <ID:0/030> Total Binary size: 6736 M <ID:0/030> SetupConnection.. <ID:0/030> Initialzation.. <ID:0/030> Set PIT file.. <ID:0/030> DO NOT TURN OFF TARGET!! <ID:0/030> Get PIT for mapping.. <ID:0/030> Firmware update start.. <ID:0/030> NAND Write Start!! <ID:0/030> SingleDownload. <ID:0/030> sboot.bin <ID:0/030> param.bin <ID:0/030> up_param.bin <ID:0/030> cm.bin <ID:0/030> keystorage.bin <ID:0/030> boot.img <ID:0/030> recovery.img <ID:0/030> system.img <ID:0/030> vendor.img <ID:0/030> dqmdbg.img <ID:0/030> userdata.img <ID:0/030> modem.bin <ID:0/030> Transmission Complete.. <ID:0/030> Now Writing.. Please wait about 2 minutes <ID:0/030> Receive Response from boot-loader <ID:0/030> modem_debug.bin <ID:0/030> Transmission Complete.. <ID:0/030> Now Writing.. Please wait about 2 minutes <ID:0/030> Receive Response from boot-loader <ID:0/030> cache.img <ID:0/030> omr.img <ID:0/030> odm.img <ID:0/030> hidden.img <ID:0/030> RQT_CLOSE !! <ID:0/030> RES OK !! <ID:0/030> Remain Port .... 0 <OSM> All threads completed. (succeed 1 / failed 0) <ID:0/030> Removed!! <ID:0/086> Added!!
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. Last edited by ...:::::NP™:::::...; 07-27-2018 at 18:14. |
The Following User Says Thank You to ...:::::NP™:::::... For This Useful Post: |
07-28-2018, 19:25 | #393 (permalink) |
Junior Member Join Date: Jul 2018 Location: germany
Member: 2854038 Status: Offline Thanks Meter: 0 | First of all, thanks for this great community. I joined to share my Problem and hopefully add knowledge. I have a S8+ with: 8.0.0/R16NW/G955FXXU3CRGB #fail to open recovery_cause File-Based OTA Supported API: 3 Manuel Mode 1.0.0 remove failed dir /system/carrier/att/priv-app/AttIqi_att RP SWREV B:3 K:2 S:2 I cant get any method to work to remove FRP or downgrade my S8+ My latest firmware should be: Model SM-G955F Model name Galaxy S8+ Country Version Android 8.0.0 Changelist 13569719 Build date Fri, 25 May 7162 14:26:54 +0000 Security Patch Level 2018-05-01 Product code DBT PDA G955FXXU2CRED CSC G955FOXM2CREB But somehow I messed up and got: Model SM-G955FD Model name Galaxy S8+ Country Version Android 8.0.0 Changelist 13971786 Build date Mon, 16 Jul 2018 05:46:41 +0000 Security Patch Level 2018-07-01 Product code DBT PDA G955FXXU3CRGB CSC G955FOXM3CRG9 There must be someway to correct this issue? Ive tried all G955F Combo Roms Which dont work because of the firmware issue? Neither Odin nor Samsung pro Tools run clean, I end up with RP SWREV binary 3 2 1 device 3 2 1 errors. I reckon I am missing something. Really annoyed by my mistake with the firmware. I would be most thankful for shared experience and todo I didnt try yet. |
07-28-2018, 20:14 | #394 (permalink) | |
No Life Poster Join Date: Jan 2013 Location: zimbabwe south africa
Member: 1866877 Status: Offline Sonork: 100.1681933 Thanks Meter: 707 | Quote:
07-28-2018, 20:55 | #395 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: Roumania
Member: 691388 Status: Offline Thanks Meter: 371 | Quote:
You can't downgrade.... only way is combination bit 3 then flash stock bit3 ( only sboot.boot.system.recovery.cache) or try with odin BL+AP+HomeCsc. It may help to so reset frp and factory reset in combination before flash stock. BR | |
The Following User Says Thank You to maremestera For This Useful Post: |
08-01-2018, 22:24 | #399 (permalink) |
Member: 2854038 Status: Offline Thanks Meter: 0 | First of all Thank you for guiding me thru my blindness and filling my knowledge. I managed to fix my GALAXY S8+ G955FXXU3CRGB SM-G955FD DBT GERMANY with a Bit 3 Firmware File: COMBINATION_FA70_G955FXXU3ARG1 Which can be found here on this forum. I tried to flash the combination rom several times before succeeding. I used ODIN 3.13.1 (not the B patched version). And Samsung Pro Tool 29.5. Either one managed to flash at some point. Im sure that it was a vital step to flash the complete 4 Files official G955FXXU3CRGB ROM and then factory reseting before trying to flash the combination file again. Alot of flash fails in between... and then finally it worked. What I did additionally was enabling ADB within Factory Firmware and running this script several times: (sorry cant post links yet) Not sure if that really is neccesary but my final attempt had this step involved. I basically ran the command line several times without acctually knowing if it worked. Finally restarted with Samsung pro Tool to download mode and flashed with Samsung Pro Tool 29.5 with the suggested settings and exclusions |
08-02-2018, 04:48 | #400 (permalink) |
Freak Poster Join Date: Jan 2008 Location: HH +4940
Member: 686560 Status: Offline Thanks Meter: 68 | |
The Following User Says Thank You to serpas007 For This Useful Post: |
08-02-2018, 20:58 | #401 (permalink) |
No Life Poster Join Date: Feb 2005 Location: Romania Age: 37
Member: 120579 Status: Offline Thanks Meter: 182 | Frp is enabled, ignore PIT download Frp is enabled, not allowed to download non-Frp abl binary G9650 binary2 No matter what combination file I write, this error persists ! |
08-03-2018, 18:35 | #402 (permalink) |
Junior Member Join Date: Nov 2005 Location: Polska Age: 50
Member: 200487 Status: Offline Thanks Meter: 2 | Hello Combination file please for my model binary3 Model: SM-G950U1 AP version: G950U1UES3CRE2 CSC version: G950U1OYM3CRE2 CP version: G950U1UES3CRE2 Product code: XAA Phone SN: R28JB3HVYWX |
08-07-2018, 00:19 | #405 (permalink) |
Insane Poster Join Date: Nov 2014
Member: 2298646 Status: Offline Thanks Meter: 16 | If you want to skip md5 verification remove the md5 file name prefix at the end of the file name. It could also mean the combination file downloaded was corrupt / not downloaded properly. |
