Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
05-28-2017, 09:44 | #32 (permalink) | |
Crazy Poster Join Date: May 2012
Member: 1762758 Status: Offline Sonork: 5611 Thanks Meter: 8 | Quote:
I really want to try but when i search for the stock firmware of my phone(in order to unbrick if something goes wrong with the phone),i cant find one so this is very risky if G950u fails and bricked my phone. | |
05-28-2017, 19:41 | #33 (permalink) |
Insane Poster Join Date: Feb 2008
Member: 709565 Status: Offline Thanks Meter: 6 | Needed root to get msl code, flashed twrp recovery for the root. After i tried maze and atiroot software and all got error, unable to mount partition data, somethhing like that so i decided to reflash soft that give me error with fit file. After i did success install the combinatii. File but factory mode did not finish boot. The download mode is a black screen with some steange text. What can i do to flash good firmware and root for msl code ? Final destinatio. Is unlock via z3x. Mention frp is off on the phone. G955F |
05-28-2017, 22:39 | #35 (permalink) |
Member: 709565 Status: Offline Thanks Meter: 6 | Operation: Flash Selected model: SM-G935F Software version: 28.2 File analysis... Ok Total file size: 0x15F58C277 (5621 Mb) Searching USB Flash interface... COM15 detected Setup connection... Ok Set PIT file... Error Done with Samsung Tool PRO v.28.2 Managed to flash something with odin but i still get this. please help? |
05-28-2017, 22:56 | #36 (permalink) |
Member: 709565 Status: Offline Thanks Meter: 6 | <ID:0/015> Odin engine v(ID:3.1203).. <ID:0/015> File analysis.. <ID:0/015> SetupConnection.. <ID:0/015> Initialzation.. <ID:0/015> Set PIT file.. <ID:0/015> DO NOT TURN OFF TARGET!! <ID:0/015> FAIL! <ID:0/015> <ID:0/015> Re-Partition operation failed. <OSM> All threads completed. (succeed 0 / failed 1) same error in odin.. i dont know how to fix this |
05-28-2017, 23:52 | #37 (permalink) |
Insane Poster Join Date: Feb 2016
Member: 2528751 Status: Offline Thanks Meter: 11 | u need to flash only the boot sboot from combination and press adb frp reset over z3x... and than after unlocked frp and OEM Unlock u can flash boot sboot from correct stock firmware back... to flash complete combination firmware is risky....as u can see in this post many devices dead... |
The Following 2 Users Say Thank You to pclion For This Useful Post: |
05-29-2017, 02:08 | #39 (permalink) | |
Member: 2528751 Status: Offline Thanks Meter: 11 | Quote:
what is the last state of your device ? black background with green text ? if yes so force your device by holding power vol down home to get into download mode by pressing for 1 minute .. | |
The Following User Says Thank You to pclion For This Useful Post: |
05-29-2017, 02:20 | #40 (permalink) |
Member: 709565 Status: Offline Thanks Meter: 6 | phone has combination file flashed. will not boot fully. if i try download mode it has black screen like in the picture, i try to flash BL file a few seconds then cancel and then i can access download mode normal but if i want to flash ... with full load ap csc bl it just stops at pit file... |
The Following User Says Thank You to n1viperx For This Useful Post: |
05-29-2017, 10:28 | #42 (permalink) | |
No Life Poster Join Date: Apr 2014 Location: Worldwide
Member: 2174901 Status: Offline Sonork: 100.1671257 Thanks Meter: 1,248 | Quote:
05-29-2017, 10:28 | #43 (permalink) | |
05-29-2017, 10:31 | #44 (permalink) | |
05-29-2017, 10:33 | #45 (permalink) | |
and flash it | |
