Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 05-29-2017, 16:47   #46 (permalink)
Member: 709565
Thanks Meter: 5
Managed to flash system image and got error at hidden.img but managed to boot in normal mode, still cat get msl code
Nothing works, also i have phone rooted.
Where do i get msl code. I install terminal
su
getprop ril.MSL
And it just jump a row and nothing showing
screen capture windows
Really sorry if I got off topid but this is important as well for unlock
Old 05-30-2017, 00:25   #47 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 107
Exclamation
hello
tried your solution but no joy for me :
1. flashed COMBINATION_FA70_G955FXXU1AQDB
2. flashed with Z3X only system+sboot+boot+recovery+cache from G955FXXU1AQDG_OXM1AQDG_TUR
3. it gives some error and goes to recovery, i hit REBOOT, then asks for reset, and is only a RESET option in lower screen
4. restarts, and Google account is on
pls clarify some aspects :
a) wich version you flash after combination ?
b) if flashing sboot and boot from regular firmware, it means no more adb ?
c) before flashing COMBINATION, what version was on your S8+ ?
thanks
The Following 2 Users Say Thank You to nbkappa For This Useful Post:
Old 05-30-2017, 03:44   #48 (permalink)
Member: 1544599
Thanks Meter: 210
deAR bro pls this file have the password
SM-G950U : G950U-P-T-V-A-R4 ARABIC MULTILANGUAGE
pls help
Old 05-30-2017, 11:44   #49 (permalink)
Member: 2174901
Sonork: 100.1671257
Thanks Meter: 1,092
su
getprop ril.MSL
Hello bro this thread Only for frp not msl.
Old 05-30-2017, 11:45   #50 (permalink)
Member: 2174901
Sonork: 100.1671257
Thanks Meter: 1,092
Originally Posted by nbkappa View Post
hello
thanks
Try This
Flash combination then system+recovery+cache then flash sboot+boot
Old 05-30-2017, 11:46   #51 (permalink)
Member: 2174901
Sonork: 100.1671257
Thanks Meter: 1,092
pls help
the password: halabtechteam
The Following 2 Users Say Thank You to hosam kashto For This Useful Post:
Old 05-30-2017, 19:00   #52 (permalink)
romell's Avatar
Member: 252707
Thanks Meter: 17
i cant flash COMBINATION_FA70_G950FDXU1AQD1_Halabtech with z3x error in setup... device show: odin protocol version error.
File analysis... Ok
Total file size: 0x7CCA2DBC (1996 Mb)
Searching USB Flash interface... COM5 detected
Setup connection... error
Done with Samsung Tool PRO v.28.1
i try with odin 3.12.5 error FAIL SHA256 is invalid
Old 05-30-2017, 22:26   #53 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 107
Arrow
Originally Posted by hosam kashto View Post
Try This
hello
followed your tutorial on youtube and after COMBINATION, did NORMAL (regular) firmware flashed in 2 steps :
1st. system+recovery+cache then reboot, and then some errors...skipped over and then
2nd. sboot and bin
this is exactly as it was done in youtube.
my result : bootloop. no matter wich COMBINATION and then Normal firmware, same bootloop.
tried different files of COMBINATION and normal, but always bootloop.
on youtube cant see EXACTLY wich firmware was used for combination, and after, wich firmware was used for normal flasing.
so, if you would be kind and share full info...
thanks
Old 05-31-2017, 11:35   #54 (permalink)
Member: 2174901
Sonork: 100.1671257
Thanks Meter: 1,092
File analysis... Ok
Bro be sure your device in download mode and you have all driver installed
Old 05-31-2017, 11:36   #55 (permalink)
Member: 2174901
Sonork: 100.1671257
Thanks Meter: 1,092
hello
2nd. sboot and bin
thanks
I use the same firmware I shared here try to flash 4 files and try again
The Following User Says Thank You to hosam kashto For This Useful Post:
Old 05-31-2017, 12:23   #56 (permalink)
nbkappa's Avatar
Member: 595864
Thanks Meter: 107
tried, but no chance...
done it in 5 min by official
thanks for sharing and support
Old 06-02-2017, 05:03   #57 (permalink)
Member: 1476691
plaease combination file sm-g955n thank you sir
Old 06-02-2017, 20:46   #58 (permalink)
Member: 2174901
Sonork: 100.1671257
Thanks Meter: 1,092
I don't try but you can use the same g955f because the same cpu
Old 06-04-2017, 19:03   #59 (permalink)
CRM
Member: 1176826
Sonork: 100.1604160
Thanks Meter: 41
What Is The Use Of Enable OEM ????
Old 06-04-2017, 19:16   #60 (permalink)
Member: 481573
Thanks Meter: 43
enable OEM will disable frp activatin so frp will turn off
Page generated in 0.41421 seconds with 8 queries
