Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
06-10-2017, 00:27 | #63 (permalink) |
Registered User Join Date: Aug 2007 Location: United Kingdom
Member: 567838 Status: Offline Thanks Meter: 64 | i am having problem with s8 g950f i have flashed with comination file i enable usb debugging power off phone and enter download mode using odin i flash ap ,bl, csc ,using your files odin flashes but gives fail at end because of frp |
06-10-2017, 07:18 | #65 (permalink) |
Member: 567838 Status: Offline Thanks Meter: 64 | what am i doing wrong 1. flashed combination file 2. enabled usb debugging 3. i Dont see OEM in settings or anywhere in menu to enable 4. powered phone off , eneter download mode using odin 5. using G950FXXU1AQDD_OXM1AQDD_Arabic_v7.0_Halabtec i flash all 4 parts BL , AP , CP, CSC 6. Gives error on phone , custom binary omr , blocked by frp lock please advise exactly how to enable oem and exactly which parts of G950FXXU1AQDD_OXM1AQDD_Arabic_v7.0_Halabtec need to be flashed and what is meant by hard reset, through phones menu or volume power up |
The Following User Says Thank You to MORRISGSM For This Useful Post: |
06-10-2017, 10:39 | #67 (permalink) |
Moderator Join Date: Nov 2009 Location: €urope Age: 41
Member: 1162626 Status: Online Sonork: 100.1591727 QQ:2337938173 Thanks Meter: 11,110 | @ nbkappa Please read this thread carefully from beginning. Especially:- http://forum.gsmhosting.com/vbb/12516821-post19.html http://forum.gsmhosting.com/vbb/12519940-post30.html
__________________ -------------------------- Use Search Button to get Instant Result | Follow Forum Rules Avoid Spams in the forum to prevent ban your account. |
06-10-2017, 10:42 | #68 (permalink) | |
Member: 567838 Status: Offline Thanks Meter: 64 | Quote:
CUSTOM BINARY (OMR) Blocked by FRP | |
06-10-2017, 11:25 | #69 (permalink) | |
I can enable usb debugging with combination file i have attempted to flash BL , AP AND CSC HOME With the firmware provided at this post , it says CUSTOM BINARY FRP OMR BLOCKED With other ORIGINAL stock firmwares , stops at CSC , hidden i think it may be Boot protected to only flash with the original software of the phone that is 3UK but i am not sure why this is happening but it is not allowing combination file then only BL AP AND CSC | |
