Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
06-17-2017, 00:42 | #82 (permalink) |
Freak Poster Join Date: Jan 2012 Location: On Earth
Member: 1716439 Status: Offline Thanks Meter: 38 | Samsung S8 / S8 Plus 100% Working [FRP][RESET][SOLUTION] !!! all work smooth and fine like silk. wbr. Last edited by dcosmin22; 06-27-2017 at 17:42. |
The Following User Says Thank You to dcosmin22 For This Useful Post: |
06-18-2017, 08:38 | #85 (permalink) | |
Member: 1716439 Status: Offline Thanks Meter: 38 | Samsung S8 / S8 Plus 100% Working [FRP][RESET][SOLUTION] !!! Quote:
Friend , Read full post and you will see, confirmed that is true fact. I was removing OEM and FRP account of G955F/ S8+ Last edited by dcosmin22; 06-18-2017 at 15:40. | |
06-19-2017, 20:49 | #87 (permalink) | |
Member: 1716439 Status: Offline Thanks Meter: 38 | Quote:
If YOU have pro version you can se that before x mark sign, or uncheck every field you can select every file on each line(ap, bl, cp, csc). This option in on the right side marked with ..(two points). So if more explanation than this needed than you must go to school( i' m joking). Hope will help. Good day. | |
06-19-2017, 23:47 | #88 (permalink) |
Major Poster Join Date: Sep 2015
Member: 2456749 Status: Offline Thanks Meter: 7 | sorry i was trying to run it through odin but he said the sboot file is needed not the actual bootloader which is what i am having trouble finding like what use to exist on the sm-g925 phones when you extracted firmwares youd find a sboot.bin but on these firmwares i dont find them at all |
06-19-2017, 23:47 | #89 (permalink) | |
Member: 2456749 Status: Offline Thanks Meter: 7 | Quote:
06-20-2017, 06:04 | #90 (permalink) |
Member: 2456749 Status: Offline Thanks Meter: 7 | if you use the sm-g955u eng-root you can avoid the entire combination issue and just run the adb command "adb shell content insert --uri content://settings/secure --bind name:s:user_setup_complete --bind value:s:1" (without quotation marks) and youll bypass the frp then just enable developer and enable oem unlock and usb debugging and youll resolve it. Hope this helps those like me who couldn't resolve using the files provided. I am sure they work just couldnt figure it out. This method im not sure who developed it at all but i was told by local friend so i do not want to take any credit. P.s. the eng-root file can be found on here just look for bawanyh he posted the files. |
The Following User Says Thank You to jeremy93 For This Useful Post: |
