Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
06-28-2017, 23:07 | #107 (permalink) |
Freak Poster Join Date: Oct 2010
Member: 1422819 Status: Offline Thanks Meter: 45 | Thanks guys i will share my success story to remove FRP from G955F Samsung Galaxy S8+ Phone Firmware was G955FXXU1AQF7 Downloaded both files from the given link 1. COMBINATION_FA70_G955FXXU1AQDB_Halabtech 2. G955FXXU1AQDG_OXM1AQDG_TUR_Halabtech_7.0 There was no password on the rar files , successfully unrar removed the .md5 extenstion from combinaton file as it will give error in Odin I used Odin 3.12.3 , in AP browse the combination file , Flash it Phone will reboot and bring home screen where it will give you option to go into the settings and enable usb debugging. Switch off your phone , put it in download mode again , Open Odin Browse All files from G955FXXU1AQDG_OXM1AQDG_TUR_Halabtech_7.0 folder. I used HOME_CSC_OXM_G955FOXM1AQDG_CL11168760_QB13362118_R EV00_user_low_ship.tar in CSC as there is another file present in the folder. Press Start and after pass phone will boot directly to the home screen without FRP No errors at all. Thanks everyone |
The Following 14 Users Say Thank You to errorcode999 For This Useful Post: |
06-29-2017, 18:20 | #108 (permalink) |
Freak Poster Join Date: May 2017 Location: italia
Member: 2722656 Status: Offline Thanks Meter: 68 | FRP S8 S8+ MEGLIORE GUIDA.....FUNCTIONS 100% Last edited by ...:::::NP™:::::...; 07-01-2017 at 08:44. Reason: Youtube link correction |
The Following 7 Users Say Thank You to salamihassan For This Useful Post: |
07-06-2017, 09:01 | #109 (permalink) |
Freak Poster Join Date: May 2014
Member: 2189365 Status: Offline Sonork: 1614214 Thanks Meter: 22 | Sir, SM-G955F frp remove success but after after frp remove no imei, baseband unknown, i have flash many rom many modem but not solve yet, any one can help,.... |
The Following 2 Users Say Thank You to hacker.spone For This Useful Post: |
07-07-2017, 17:36 | #110 (permalink) |
Junior Member Join Date: Apr 2016
Member: 2558440 Status: Offline Thanks Meter: 4 | Big Thank you to hosam kashto for uploading these files!!!i did g955f frp and it was successful.....More grease to your elbow! |
The Following User Says Thank You to kaacee For This Useful Post: |
07-07-2017, 17:49 | #111 (permalink) |
Freak Poster Join Date: May 2010 Location: Tranqui Panqui
Member: 1309482 Status: Offline Thanks Meter: 26 | Here an explanation!. If you read the post carefuly, you can did it all with out problem. Any way. First: Flash combination file (I did it all with z3x using G935f, my phone G950f) Second: Flash normal firmware, go to flash section z3x, presets and choose the firmware carpet, then you will see "..." click there, just mark: BOOT: sboot.bin PDA:boot.img , recovery.img , sistem.img PHONE: CSS: cache.ima. And flash. That set. Thank you for the files, and explanation. Work for me like a charm!. Cheers! |
The Following 10 Users Say Thank You to Nitto777 For This Useful Post: |
07-14-2017, 01:00 | #115 (permalink) |
Member: 1422819 Status: Offline Thanks Meter: 45 | Today i tried to remove FRP on S8 G950F which was unsuccessful. I will try to explain here how i successfully completed the frp removal. Download combination file from this post and flash it through odin in AP. Dont use the stock firmware file for G90F as it will give error in flashing. use the link i have given to download the file , it will give you no error and you can be able to see OEM Unlock option. Just follow the procedure below After combination file flashing through odin , Phone will reboot and bring home screen where it will give you option to go into the settings and enable usb debugging. (There will be no option of OEM Unlock so dont worry). Power off your phone , Put it again in download mode download the firmware from the below link. Use all 3 files and flash it. Go straight into the settings and tap 7 times for debugging on , you will see oem unlock , slide it on and factory reset. FRP removed https://drive.google.com/file/d/0Bzq...1NNldMMUU/view |
07-14-2017, 12:30 | #116 (permalink) |
Junior Member Join Date: Jul 2017
Member: 2736548 Status: Offline Thanks Meter: 0 | Hi Guys, Is there an available binary combination for s8 sm-g950n korea Telecom? Or do you have instructions on how to bypass frp lock to this model? Your help is highly appreciated guys! Thank You! |
07-19-2017, 22:13 | #118 (permalink) |
No Life Poster Join Date: May 2005 Location: Bacau
Member: 148032 Status: Offline Thanks Meter: 415 | This solution work on G950H ?...I can't find combination file form g950h...I only have for G950f and G950U, Are these combination files compatible with g950H, I don't want to brik it!!! ????? |
07-20-2017, 06:19 | #119 (permalink) | |
Freak Poster Join Date: Jan 2016 Location: Afghanistan
Member: 2520139 Status: Offline Sonork: masoudsoftware Thanks Meter: 300 | Quote:
The New samsung model dont have boot .just give you erorr if not accept the job is full off risk Say again just do it | |
