Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
01-25-2010, 16:49 | #1 (permalink) |
Junior Member Join Date: Nov 2009
Member: 1160418 Status: Offline Thanks Meter: 0 | Samsung SGH-G800 Debranding and Flashing having become quite proficient at working on SE phones I am now trying to sort out this old G800. Could anyone please tell me which software to use in order to debrand this phone. Also, I would require the newest generic Samsung Firmware etc.. which is available and any files that would be needed. Any help and tips will be greatly appreciated! Thank's to all in advance, Orange |
01-25-2010, 17:01 | #3 (permalink) |
No Life Poster Join Date: Dec 2004
Member: 97600 Status: Offline Thanks Meter: 97 | any xx files are generic unbranded and my advice is search on the forum for posts that have successfully flashed this phone before you flash it and dont flash the boot files as you may kill it. if you haven't got a box like nspro or z3x then use multiloader 5.33 that will do it |
The Following User Says Thank You to ringtons For This Useful Post: |
01-25-2010, 17:28 | #5 (permalink) |
Member: 1160418 Status: Offline Thanks Meter: 0 | Aditionally, could someone please explain which files would be needed for debranding? (With SE phones it would be: MAIN, FS and CDA) Thank's for all the lightning-speed replies so far... :-) |
01-25-2010, 18:32 | #6 (permalink) |
Member: 97600 Status: Offline Thanks Meter: 97 | here you go a picture is worth a thousand words keep your port number low it works better also connect phone first via usb without running soft to install drivers |
01-25-2010, 22:55 | #7 (permalink) | |
Member: 1160418 Status: Offline Thanks Meter: 0 | Quote:
Thank's guys for all the help! The picture attchment showed it all - Special thank's to Ringtons!!! Flashed the phone with G80LXXHB1 files and see there! Debranded! Managed to debrand 2 of the same phones one which was dead beforehand, the screen kinda worked now so I'll just fit (solder) another ribbon in and it should spark. Thank you all again...! | |
01-26-2010, 14:42 | #8 (permalink) |
No Life Poster Join Date: Mar 2004 Location: LGE
Member: 57760 Status: Offline Sonork: 100.1579298 Thanks Meter: 3,510 | G800 Unbranded Firmware http://rapidshare.com/files/341362596/G800_XXGL1.zip |
The Following User Says Thank You to nasirahmed For This Useful Post: |
samsung sgh g800 | igorcic | Samsung Hardware Repair | 0 | 01-04-2009 11:22 |
adding arabic language to Samsung SGH-G800 | shokoup | Samsung Flashers, Software, Firmware. | 2 | 05-28-2008 12:43 |
Unlocking Samsung SGH-G800? | DLAMusic | Samsung Flashers, Software, Firmware. | 2 | 05-24-2008 10:18 |
Unlock Samsung SGH-G800 | RajKaria222 | VLSI, Conexant, Skyworks and Old Models | 0 | 01-10-2008 21:34 |
