Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
10-18-2008, 19:24 | #1 (permalink) |
Junior Member Join Date: Oct 2008
Member: 878627 Status: Offline Thanks Meter: 1 | Samsung SGH-U600 firmware update adventures - any advice? As this phone is NOT sold or used by any carrier in the USA, I decided to see if maybe getting a "newer" firmware might fix the problem. Looking at: http://frontside.be/word/2007/09/18/...u600-firmware/ as reference, the original revision that I had on this phone was: U600BOGI1 (T-Mobile carrier code with a September 2007 rev. 1) I then decided to "flash" this phone with OptiFlash to the "newest" version, which I could find: U600XXGK2 ("Generic Western European" code with November 2007 rev. 2) The flash went all okay, but when I restarted the phone, it would not accept any SIM cards. I tried 3 different cards, but I would still get an "Insert SIM card" message upon turning the phone on. However, when I tried to do the test codes on the phone, all was okay. And the diag code confirmed that the new firmware was indeed correctly flashed. I then decided to "flash" the phone again to this revision: U600BOGD4 (T-Mobile carried code with April 2007 rev 4.) and now it is working again normally. I don't know if my problems have been fixed, as I have had this newer firmware for only 6 hours. So, my question is this: Why would an UNLOCKED phone not work with that November 2007 revision? I assume that there is something still something in that phone which only allows it to work with a T-mobile related firmware. There are number of "T-mobile" only related options in this (& original) firmware (like Web'n'Walk , T-zones), and I would not mind loosing them since I use AT&T. I am also wondering if the current firmware that I am using now from April 2007 revision 4 is "better" then what I had originally, which was September 2007 revision 1? Any comments or suggestions are much appreciated! |
The Following User Says Thank You to mystiky For This Useful Post: |
Samsung SGH-U600 Unlock | audiotob | VLSI, Conexant, Skyworks and Old Models | 4 | 07-07-2014 10:16 |
samsung sgh-u600 | kolas | Samsung Flashers, Software, Firmware. | 0 | 10-24-2009 11:09 |
samsung sgh u600 | darren23071980 | Samsung Hardware Repair | 0 | 03-11-2009 20:55 |
samsung SGH-U600 error unlock | glontz | Easy-Unlocker | 2 | 11-14-2008 13:28 |
