Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
11-24-2008, 20:27 | #1 (permalink) |
Junior Member Join Date: Nov 2007
Member: 624203 Status: Offline Thanks Meter: 0 | Flashing E590 problems I have already downloaded proper firmware, OneNAND downloader ... spent many hours on looking for one issue. I should probably start with a question if I can flash it with the cable that came as standard (PCB200BSE). When I connect phone to the computer it detects it as modem (on port 24) and in USB as Samsung usb device. There is nothing in the Ports section (where it should be something like usb to serial?). I have installed the pc suite. When I am choosing port 24 in OneNANAD and click START I see turn the phone on .... and I am trying a quick click on the power button ... longer one that turns the phone normally ... still nothing happens. In a nutshell if someone has some time, pointing a right direction (model of a proper cable, or things I can be doing wrong) would be highly appreciated. Thank you very much for your time. Regards, Vermonek |
d780 flashing problem...after flashing ringer problem | gsm st | SWIFT Platform | 2 | 03-22-2009 22:29 |
how to flash e590 in ust pro | wilnert | UST Pro II | 2 | 02-03-2009 10:31 |
how to flash e590 | 2net2 | UST Pro II | 4 | 01-30-2009 09:22 |
Flash e590 | sonkar | UST Pro II | 0 | 06-30-2008 18:12 |
can i use an other model to flash e590 | stranger55 | UST Pro II | 0 | 06-16-2008 18:17 |
