Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Samsung > Samsung Flashers, Software, Firmware.
Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms.
Old 05-22-2005, 23:26   #1 (permalink)
Member: 134637
Thanks Meter: 2
samsung unlock codes
samsung d500 e700 and other phone unlock codes free email me for more
The Following 2 Users Say Thank You to soneill525 For This Useful Post:
Old 05-23-2005, 20:42   #2 (permalink)
Member: 19638
you have codes by samsung z 107
The Following User Says Thank You to Daniel1974 For This Useful Post:
Old 05-26-2005, 14:24   #3 (permalink)
GSMARMOON's Avatar
Member: 90804
Thanks Meter: 46
samsung unlock codes D500?
HI.
D500:*2767*3855# = E2P Full Reset
*2767*2878# = E2P Custom Reset. GOODLUCK
The Following 2 Users Say Thank You to GSMARMOON For This Useful Post:
Old 05-26-2005, 16:29   #4 (permalink)
Member: 101426
Question
Originally Posted by GSMARMOON
HI.
Hey!! What about E105 codes?
Old 05-26-2005, 21:57   #5 (permalink)
Member: 134637
Thanks Meter: 2
try #*7337# that might work for it
Old 05-28-2005, 13:57   #6 (permalink)
GSMARMOON's Avatar
Member: 90804
Thanks Meter: 46
Unlocking codes for Samsung?
v200, s100, s300
1. press *2767*63342#
2. press *2767*3855#
3. press *2767*2878#
4. press *2767*927#
5. press *2767*7822573738# unlocked code
6. now ur phone unlocked
Unlock code for:
A800/A300 - *2767*637#
V200 - *2767*7822573738#
S500/X100/samsung E700/S500/X600/430/410 - *2767*688# OR TRY NEW CODE #*7337#
*#8999*8378# (All in one code)
*#4777*8665# (GPRS TOOL)
*2767*2878# reset codes for Samsungs plus resets security codes BACK TO 00000000
SGH-600:
*2767*3855# FULL EPPROM RESET/UNLOCK CODE.
The Following 9 Users Say Thank You to GSMARMOON For This Useful Post:
Old 06-17-2005, 08:50   #7 (permalink)
Member: 153381
unlock e700
HI,i m new here ,i need help to unlock e700,i did try some kods,but it doesn t help or maybe i didnt know how to use it
plaese if you kan help me whith it
Old 07-05-2005, 20:15   #8 (permalink)
Member: 101426
Thanks Buddy try it i will.
Cheers
Old 07-06-2005, 14:11   #9 (permalink)
Member: 38782
Thanks Meter: 9
Posted here many times.. The codes does not work on all phones.
Old 07-07-2005, 11:10   #10 (permalink)
Member: 158710
Thanks Meter: 2
thanks for the codes.... for D500
I have luck with one phone but the secound faild? what is the solution.
thanks again
Peace
The Following User Says Thank You to agge For This Useful Post:
Old 07-08-2005, 14:24   #11 (permalink)
Member: 158710
Thanks Meter: 2
Hiii GSMARMOON
Help me with the D500 codes, it only worked on 1 phone???
Why...
Does anyone know how to get the D500 to "TAT mode" , I have a problem the phone start to charge insted?
Old 07-08-2005, 15:28   #12 (permalink)
TDXI's Avatar
Member: 111845
Thanks Meter: 2
The codes only work on the old versions and if the phone is going into charge then you are usimg the wrong cable you need the one with a 9v battery.
Old 08-04-2005, 18:16   #13 (permalink)
Member: 161585
Thanks Meter: 44
*2767*688# = Unlocking Code
*#8999*8378# = All in one Code
*#4777*8665# = GPSR Tool
*#8999*523# = LCD Brightness
*#8999*3825523# = External Display
hello boys !
i type here all samsung unlock and options code !
*#8999*377# = Errors
#*5737425# = JAVA Something{I choose 2 and it chrashed}][/b]
*#2255# = Call List
#*536961# = Java Status Code
#*536962# = Java Status Code
#*536963# = Java Status Code
#*53696# = Java Status Code
#*1200# = AFC DAC Val
#*1300# = IMEI
#*1400# = IMSI
#*2562# = ??? White for 15 secs than restarts.
#*2565# = Check Blocking
#*3353# = Check Code
#*3837# = ??? White for 15 secs than restarts.
#*3849# = ??? White for 15 secs than restarts.
#*3851# = ??? White for 15 secs than restarts.
#*3876# = ??? White for 15 secs than restarts.
#*7222# = Operation Typ (Class C GSM)
#*7224# = I Got !! ERROR !!
#*7252# = Oparation Typ (Class B GPRS)
#*7271# = Multi Slot (Class 1 GPRS)
#*7274# = Multi Slot (Class 4 GPRS)
#*7276# = Dunno
#*7337# = EEPROM Reset (Unlock and Resets Wap Settings)
#*2787# = CRTP ON/OFF
#*3737# = L1 Dbg data
#*5133# = L1 Dbg data
#*7288# = GPRS Attached
#*7287# = GPRS Detached
#*7666# = SrCell Data
#*7693# = Sleep Act/DeAct (Enable or Disable the Black screen after doing nothing for a while)
#*7284# = Class : B,C or GPRS
#*2256# = Calibration Info
#*2286# = Battery Data
#*2527# = GPRS Switching (set to: class 4, class 8, class 9 or class 10)
#*2679# = Copycat feature (Activate or Deactivate)
#*3940# = External loop test 9600 bps
#*4263# = Handsfree mode (Activate or Deactivate)
#*4700# = Half Rate (Activate or Deactivate)
#*7352# = BVMC Reg value
#*8462# = Sleeptime
#*2558# = Time ON
#*3370# = EFR (Activate or Deactivate)
#*3941# = External looptest 115200 bps
#*5176# = L1 Sleep
#*7462# = SIM phase
#*7983# = Voltage/Frequenci (Activate or Deactivate)
#*7986# = Voltage (Activate or Deactivate)
#*8466# = Old time
#*2255# = Call ???
#*5187# = L1C2G trace (Activate or Deactivate)
#*5376# = ??? White for 15 secs than restarts.
#*6837# = Official Software Version
#*7524# = KCGPRS
#*7562# = LOCI GPRS
#*7638# = RLC allways open ended TBF (Activate or Deactivate)
#*7632# = Sleep mode Debug
#*7673# = Sleep mode RESET
#*2337# = Permanent Registration Beep
#*2474# = ???
#*2834# = Audio Path
#*3270# = DCS support (Activate or Deactivate)
#*3282# = Data (Activate or Deactivate)
#*3476# = EGSM (Activate or Deactivate)
#*3676# = Flash volume formated
#*4760# = GSM (Activate or Deactivate)
#*4864# = Dunno doesn't work on newer versions
#*5171# = L1P1
#*5172# = L1P2
#*5173# = L1P3
#*7326# = Accessory (I got Vibrator)
#*7683# = Sleep variable (8)
#*7762# = SMS Brearer CS (Activate or Deactivate)
#*8465# = Time in L1
#*9795# = wtls key
#*2252# = Current CAL
#*2836# = AVDDSS Management (Activate or Deactivate)
#*3877# = Dump of SPY trace
#*7728# = RSAV done# (Everything went to standart but nothing was deleted)
#*2677# = ARM State (None or Full Rate)
*#8999*636# = Have no clue what it is, i see 20 lines
*#9999# = Software version
*#8999*8376263# = HW ver, SW ver and Build Date
*#8888# = HW version
*#8377466# = Same HW/SW version thing
*#7465625# = Check the locks
*7465625*638*Code# = Enables Network lock
#7465625*638*Code# = Disables Network lock
*7465625*782*Code# = Enables Subset lock
#7465625*782*Code# = Disables Subset lock
*7465625*77*Code# = Enables SP lock
#7465625*77*Code# = Disables SP lock
*7465625*27*Code# = Enables CP lock
#7465625*27*Code# = Disables CP lock
*7465625*746*Code# = Enables SIM lock
#7465625*746*Code# = Disables SIM lock
*7465625*228# = Activa lock ON
#7465625*228# = Activa lock OFF
*7465625*28638# = Auto Network lock ON
#7465625*28638# = Auto Network lock OFF
*7465625*28782# = Auto subset lock ON
#7465625*28782# = Auto subset lock OFF
*7465625*2877# = Auto SP lock ON
#7465625*2877# = Auto SP lock OFF
*7465625*2827# = Auto CP lock ON
#7465625*2827# = Auto CP lock OFF
*7465625*28746# = Auto SIM lock ON
#7465625*28746# = Auto SIM lock OFF
*2767*927# = E2P Wap Reset
*2767*226372# = E2P Camera Reset
#*6420# = MIC Off
#*6421# = MIC On
#*6422# = MIC Data
#*6428# = MIC Measurement
#*3230# = Trace enable and DCD disable
#*3231# = Trace disable and DCD enable
#*3232# = Current Mode
#7263867# = RAM Dump (On or Off)
*2767*49927# = Germany WAP Settings
*2767*44927# = UK WAP Settings
*2767*31927# = Netherlands WAP Settings
*2767*420927# = Czech WAP Settings
*2767*43927# = Austria WAP Settings
*2767*39927# = Italy WAP Settings
*2767*33927# = France WAP Settings
*2767*351927# = Portugal WAP Settings
*2767*34927# = Spain WAP Settings
*2767*46927# = Sweden WAP Settings
*2767*380927# = Ukraine WAP Settings
*2767*7927# = Russia WAP Settings
*2767*30927# = GREECE WAP Settings
*2767*73738927# = WAP Settings Reset
*2767*49667# = Germany MMS Settings
*2767*44667# = UK MMS Settings
*2767*31667# = Netherlands MMS Settings
*2767*420667# = Czech MMS Settings
*2767*43667# = Austria MMS Settings
*2767*39667# = Italy MMS Settings
*2767*33667# = France MMS Settings
*2767*351667# = Portugal MMS Settings
*2767*34667# = Spain MMS Settings
*2767*46667# = Sweden MMS Settings
*2767*380667# = Ukraine MMS Settings
*2767*7667#. = Russia MMS Settings
*2767*30667# = GREECE MMS Settings
*335# = Delete all MMS Messages
*663867# = Dump Mm file
#*536961# = WAPSAR enable / HTTP disable
#*536962# = WAPSAR disable / HTTP enable
#*536963# = Serial eable / Others disable
#*53696# = Java Download Mode
#*5663351# = Wap Model ID [Your Model]
#*5663352# = Wap Model ID [SEC-SGHXXXX/1.0]
#*566335# = Wap Model ID [SEC-SGHXXXX/1.0]
*2767*66335# = Check on which model it is
*2767*7100# = SEC-SGHS100/1.0
*2767*8200# = SEC-SGHV200/1.0
*2767*7300# = SEC-SGHS300/1.0
*2767*7650# = Nokia7650/1.0
*2767*2877368# = Reset WAP Model ID to standart
bye boys ! ! ! yohoooooooooooooooooooo !!!!!!!
The Following 43 Users Say Thank You to alireza13165 For This Useful Post:
Old 08-05-2005, 21:45   #14 (permalink)
Registered User
Tapsi Jr's Avatar
Member: 8737
Thanks Meter: 2
I wanted Hungarian Wap settings Code for Samsung phones if it is aviable.
WBR
Tapsi Jr
Old 08-06-2005, 01:38   #15 (permalink)
Member: 77923
Thanks Meter: 4
good code thanks man
The Following User Says Thank You to boce For This Useful Post:
Samsung unlocking codes jkakai Samsung Flashers, Software, Firmware. 1 09-13-2011 19:55
Free Samsung Unlock Codes Enjoy. rajan nishchal Samsung (USB-Smart) 2 08-19-2006 14:15
samsung unlock code x460 and x640 osaooo Phone Unlocking Codes & Maps 2 01-24-2006 01:24
Samsung unlock code ?? S100 urgently pali Phone Unlocking Codes & Maps 0 02-14-2003 18:06
Page generated in 0.31119 seconds with 9 queries
