Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
05-11-2010, 14:17 | #1 (permalink) |
Freak Poster Join Date: Mar 2010 Location: hyderabad
Member: 1257171 Status: Offline Thanks Meter: 86 | Unlock Samsung Phone Without Cable First with different carrier SIM in phone at WRONG CARD screen ENTER on the keypad *2767*3855# (wait 10-15 seconds) phone will reboot(restart) When phone completes reboot ENTER *7465625*638*00000000*00000000# NEXT ENTER #7465625*638*00000000# AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks... network lock - inactive subset lock - inactive sp lock - inactive cp lock - inactive sim lock - inactive activa lock - inactive phone lock - inactive auto network - inactive auto subset lock - inactive auto sp lock - inactive auto cp lock - inactive also work A437 AT&T |
05-11-2010, 14:18 | #2 (permalink) |
Member: 1257171 Status: Offline Thanks Meter: 86 | Samsung SGH-M110 Tested and working Tested for unlocking had subset and network locked. i guess most of them have it. The imei stayed the same Take a non-accepted sim card. Put half of it in the phone start the phone. When you see insert sim put in all of the card. Press the code *2767*3855# now the phone restart and you should come to the menus. type *7465625*782*00000000*00000000# and after type #7465625*782*00000000# now subset lock should be unlocked. type *7465625*638*00000000*00000000# and after type #7465625*782*00000000# now the network lock should be unlocked. Turn of the phone and try if the phone is sucessfully unlocked. Subset must be unlocked first it will not work if you take network lock first |
05-11-2010, 14:18 | #3 (permalink) |
Member: 1257171 Status: Offline Thanks Meter: 86 | Samsung E635 First with different carrier SIM in phone at WRONG CARD screen ENTER on the keypad *2767*2878# (wait 10-15 seconds) phone will reboot(restart) When phone completes reboot ENTER *7465625*638*00000000*00000000# NEXT ENTER #7465625*638*00000000# AND THEN *#7465625# to check the locks....all locks are inactive...these are all the locks... network lock - inactive subset lock - inactive sp lock - inactive cp lock - inactive sim lock - inactive activa lock - inactive phone lock - inactive auto network - inactive auto subset lock - inactive auto sp lock - inactive auto cp lock - inactive |
05-11-2010, 14:18 | #4 (permalink) |
Member: 1257171 Status: Offline Thanks Meter: 86 | E250 unlocking code 1. First do a CUSTOM reset: *2767*2878# 2. Take a wrong network SIM (which the phone wont accept) and insert it whilst the phone is ON, without taking the battery out. 3. Make a FULL reset: *2767*3855# 5. The phone should reboot working with "wrong" sim inside, and it will accept it. 6. Change the NCK password to 8 zeros: *7465625*638*00000000*00000000# 7. Disable network lock: #7465625*638*00000000# 8. Check status of phone again *#7465625# You will see that the network lock is now inactive. if the phone have sp lock active do a EEprom Reset #*7337# |
05-11-2010, 14:19 | #5 (permalink) |
Member: 1257171 Status: Offline Thanks Meter: 86 | Samsung t429 Default Unlocking T429(NO BOX REQUIRED)100%TESTED First boot it up first and then put a non accepted sim phones display insert correct sim, reset eeprom with this code *2767*3855# phone reboots and still display insert correct sim, now enter this code *7465625*638*00000000*00000000# after this code phone will hang for sometime please do not remove battery if you want to find out thta the phone has resumed from hanging keep pressing any key till you use the typed key. now enter *7465625*638*00000000# phone hangs again wait till phone resumes. if after 5mins time phone still hangs remove battery insert back power on phone and your phone is |
05-11-2010, 14:19 | #6 (permalink) |
Member: 1257171 Status: Offline Thanks Meter: 86 | Free samsung j706 unlock 1. power on phone without sim 2. insert your sim without removing battery(phone should still be on) 3. type *2767*3855# Then * type code *7465625*638*00000000*00000000# * then #7465625*638*00000000# and * then *#7465625# this code check the locks on your phone all eill be in activate Or i. Insert a non-accepted SIM & power on phone 2. At the "Incorrect SIM" (or similar error message) key in *2767*3855# 3. The phone will shut down then reboot. Do nothing for at least one minute after reboot. (Not sure why, but... the phone displays a warning to that effect just before it starts the reset). 4. Phone will show that it accepts the SIM. This is temporary! You can now proceed with the rest of the procedure beginning with the sequence *74656258*638*........etc. The zeros will probably show as a dash. That's normal. just make sure that you get the number of zeros correct. |
05-11-2010, 14:19 | #7 (permalink) |
Member: 1257171 Status: Offline Thanks Meter: 86 | Samsung's unlocking for FREE (J700 ) This method is maybe known for some of you , i test it for some models (like E250 ,J700 ..) and i think , it can work for all other models .. It's easy ,no risk at all , no cable , no drivers , but need to be handled well Today i test it on J700 , as we know ,many of us have a bad result after using box to unlock that fone ,, (bad Imei ,bad BT adress ... ) but with this method ,, EVERYTHING is FiNe 1- Power on fone ,, type : *#7465625# you will identify wich code is active , wich is inactive 2- Remove battery ,, Put your sim card , not all of it ,, just to prepare it to be full inserted , put your battery back and power on fone ,, you must see " insert sim" not "invalid sim.." 3- type : *2767*3855# your fone should restart after 1 min ,, now ,, and before it restart , push your sim card ,,without removing battery 4- your fone should work and accept the sim card ,, but if you chek locks you will find that your fone is still Loked 5- now type : *7465685*638*00000000*00000000# your UNLOCK CODE is 00000000 now , hh Enjoy 6- now , back to Locks table with : *#7465625# ,, and for each active code you can disable it ,,,here details : * Disables CP lock : #7465625*27*00000000# * Disables Network lock : #7465625*638*00000000# * Disables SIM lock : #7465625*746*00000000# * Disables SP lock : #7465625*77*00000000# * Disables Subset lock : #7465625*782*00000000# |
05-11-2010, 14:20 | #8 (permalink) |
Member: 1257171 Status: Offline Thanks Meter: 86 | E250I unlock ***sucssfull E250I not supported to unlock by ustpro nspro hwk and ather but heir its free for all This method is maybe known for some of you , i test it for some models (like E250 ,J600,J700 ..) and i think , it can work for all other models .. It's easy ,no risk at all , no cable , no drivers , but need to be handled well Today i test it on e250i , as we know ,many of us have a bad result after using box to unlock that fone , , (bad Imei ,bad BT adress ... ) but with this method ,, EVERYTHING is FiNe 1- Power on fone ,, type : *#7465625# you will identify wich code is active , wich is inactive 2- Remove battery ,, Put your sim card , not all of it ,, just to prepare it to be full inserted , put your battery back and power on fone ,, you must see " insert sim" not "invalid sim.." 3- type : *2767*3855# your fone should restart after 1 min ,, now ,, and before it restart , push your sim card ,,without removing battery 4- your fone should work and accept the sim card , , but if you chek locks you will find that your fone is still Loked 5- now type : *7465685*638*00000000*00000000# your UNLOCK CODE is 00000000 now , hh Enjoy 6- now , back to Locks table with : *#7465625# ,, and for each active code you can disable it ,,,here details : * Disables CP lock : #7465625*27*00000000# * Disables Network lock : #7465625*638*00000000# * Disables SIM lock : #7465625*746*00000000# * Disables SP lock : #7465625*77*00000000# * Disables Subset lock : #7465625*782*00000000# |
05-11-2010, 14:20 | #9 (permalink) |
Member: 1257171 Status: Offline Thanks Meter: 86 | Samsung SGH i710 Free Unlock 0- Phone powered off without Sim card . 1- Do a hard rest : Windows key + OK Button + Reset with stylus 2- Wait for phone to start and insert sim witout turning the phone off . 3- Go to dial option and put *2767*3855# 4- Wait for phone to start again and put this code *7465625*638*00000000*00000000# 5- Finally enter this code #7465625*638*00000000# Phone unlocked Tested with few pieces |
need ericsson 88 cable | migdamas | Old Ericsson Phones & Sony Phones | 2 | 03-24-2017 16:24 |
8810 mbus-cable | zfrank | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 05-19-1999 13:12 |
