Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
03-23-2015, 15:44 | #16 (permalink) |
No Life Poster Join Date: Mar 2010 Location: Abidjan,ivory coast
Member: 1272267 Status: Offline Sonork: 100.1667652 Thanks Meter: 408 | <ID:0/014> Added!! <OSM> Enter CS for MD5.. <OSM> Check MD5.. Do not unplug the cable.. <OSM> Please wait.. <OSM> MD5 hash value is invalid <OSM> i9505 efs.tar.md5 is invalid. <OSM> End... |
The Following User Says Thank You to Freeboy08 For This Useful Post: |
03-23-2015, 16:09 | #17 (permalink) |
No Life Poster Join Date: May 2010 Location: India,Tamilnadu-Nagercoil Age: 37
Member: 1314938 Status: Offline Sonork: 100.1672340 Thanks Meter: 5,373 | remove the .md5 extension nd flash Br james |
The Following User Says Thank You to jamesjerss For This Useful Post: |
05-24-2018, 12:06 | #20 (permalink) |
Crazy Poster Join Date: Aug 2017 Location: Nepal Age: 28
Member: 2747423 Status: Offline Sonork: [email protected] Thanks Meter: 35 | REPAIR INSTRUCTIONS: Phone must be rooted! If the software can't root the phone automatically, then you must root your device manually. 1. Power on the phone. 2. Enable 'USB debugging' in 'Settings'-'Developer options' for Android 4.0 - 4.1.2 or tap 7 times on 'Build number' in 'Settings'-'About phone' to enable 'Developer options' in Android 4.2+. 3. Connect the phone to PC with USB cable, install drivers if needed. 5. Select device in ADB settings. 6. Fill values what you need to repair. 7. Press 'Repair' button. 8. Press 'Reset EFS' if you need to reset it. Be carefully, do not perform this without necessity and make backup before. 9. Press 'Disable Factory Mode' or 'Patch Certificate' if needed. If your phones IMEI became null/null after 'Patch Certificate' operation, then this phone have different hardware and patching is not possible for it. Just fully reflash the phone and IMEI will restore. 'Wipe EFS/NVM': 1. Power on the phone in download mode (turn off phone, hold Volume Down + Home + Power). 2. Connect USB cable, install drivers if needed. 3. Press 'Wipe EFS/NVM' button to deactivate security. 4. Wait till phone reboot. Operation: Reset MSL Selected model: GT-I9505 Selected port: COM13 SAMSUNG Mobile USB Serial Port Software version: 32.2 Reading phone info... Reading IMEI... OK IMEI: 359921059842504 Reseting MSL security... OK Reseting... OK Reset MSL done Done with Samsung Tool PRO v.32.2 |
