Samsung Flashers, Software, Firmware. all Universal Software, Flashers, Editors, Unlockers, Secrets codes which support Mutliple Samsung platforms. |
07-03-2008, 21:10 | #1 (permalink) |
Freak Poster Join Date: May 2004 Location: france Age: 43
Member: 67076 Status: Offline Thanks Meter: 5 | Using "RESET E2P" exploit for SWIFT phone as i saw in the forum a good way to unlock phone with keypad using a hole in the reset *2767*3855#. By inserting sim card when the phone is "on" you can personnalize the NCK code. This method seems to be nice for new swift phone (even latest E250,G600,J700...) I wonder if i can apply external power supply on phone if the trick is good for phone with no sim card connector on the top of back of the phone. I already tested E250D,J700,G600 ,D900 seems to work. So if you have a swift phone in your hand,try this method and try to experiment with other model. The method: Power on phone. Keep phone on and insert incorrect sim card (here you still have "insert sim card" on the screen) Make a E2P reset *2767*3855#. Phone reboot and you must have your card accepted now. After that *7465625*638*00000000*00000000# For finishing #7465625*638*00000000# Now you must have an unlocked phone. Please post here your experience using this exploit. |
07-04-2008, 09:08 | #3 (permalink) |
No Life Poster Join Date: Mar 2006 Location: lost in a supermarket
Member: 239318 Status: Offline Thanks Meter: 51 | this is special helpful for box users too, me personally tried time ago on a c180 movistar that wasn't able to go in tat mode with nspro for unlock , this procedure helped me |
08-17-2008, 13:01 | #7 (permalink) |
Member: 67076 Status: Offline Thanks Meter: 5 | Imei is correct,i just insert card in 75%,i power on phone and take battery connected ,after that with screwdriver i put card inserted 100%.and i can use the method.No damaged imei or bluetooth. |
10-22-2008, 17:17 | #10 (permalink) |
Junior Member Join Date: Oct 2008
Member: 882473 Status: Offline Thanks Meter: 2 | step number one works great. step number 2 for me says already personalized. and step number 3 says wrong password. someone please help me finish this process. im with fido and using the SGH-e747 |
Solution for DEAD PHONE after flashing with mobileEx 3.3 (rev1.7_fixed)!! | curvenger | MXKEY Nokia Flasher and Unlocker (by Alim Hape) | 16 | 01-09-2011 17:00 |
SETOOL 3 Box...can't use it like interface for others phones or softwares? | chatfan | SETool2 | 2 | 03-31-2009 23:47 |
K750 CID36 converted to W800. after "reset total call time ..." phone DEAD | PSG | SonyEricsson (USB-Smart) | 2 | 08-11-2006 15:22 |
I am looking for SYM, MAP files for SWIFT phones. | Vadiks | SWIFT Platform | 0 | 03-16-2006 06:58 |
