Infineon C16X M51 & ARM7 M52 BASED MYxxx: MY3078, MY3026, MY3027 MWxxx: MW3052, MW3042, MW3040, MW3020, MW936, MW939, MW939, MW930, MW940, MW3026, MW3027 MCxxx: MC3000, MC959, MC950, MC940, MC939,MC936, MC932, MC912, MC850, MC825, MC820, MC922 RCxxx: RC922, RC750, RC730 WAxxx: WA3050 |
02-07-2001, 19:30 | #1 (permalink) |
No Life Poster Join Date: Oct 2000 Location: Croatia Age: 50
Member: 2254 Status: Offline Thanks Meter: 3 | 939 (S5-D2) hard failure need help Today I recive one Sagem 939 with "Hardwer failure Mobile blocked" massage. It ic 939 S5-D2.I can`t fix it with Sagem Dr. or with Sag.1.53 by Bartek I need help. Does anybody know how to fix it? Thanks Cole |
02-07-2001, 20:48 | #2 (permalink) |
Freak Poster Join Date: Oct 2000 Location: Bulgaria Age: 54
Member: 2419 Status: Offline Thanks Meter: 0 | Hi. It's work for 922 4.1M If you want to reset wrong code counter, you have to read EEPROM and find 9C 03 40 00 next byte is wrong code counter. This field is write/read protected, and you can't modifay it with cabele. |
02-07-2001, 22:02 | #4 (permalink) | |
Freak Poster Join Date: Jun 2000
Member: 1641 Status: Offline Thanks Meter: 54 | hi http://www.thoic.net/gsm/ubb/smile.gif yes, working solution for fix hard. failure perm. blocked. tested with mc922 4.1M. b.r. LIKI999. Quote:
02-07-2001, 22:14 | #5 (permalink) |
Member: 2254 Status: Offline Thanks Meter: 3 | Hi friends YES it realy work.I just test it on 939 S5-D2 Many Thanks - http://www.thoic.net/gsm/ubb/smile.gif Regards Cole |
02-08-2001, 19:03 | #8 (permalink) |
Member: 2254 Status: Offline Thanks Meter: 3 | Hi Phone work OK now with orginal sim card D2. When I try to unlock it with Dejans - *bad data* http://www.thoic.net/gsm/ubb/frown.gif I try with field 191=251 and etc but always *bad data* http://www.thoic.net/gsm/ubb/frown.gif Any solution for that? Regards Cole |
02-16-2001, 13:10 | #10 (permalink) |
Junior Member Join Date: Feb 2001 Location: Croatia
Member: 3361 Status: Offline Thanks Meter: 0 | No need to desolder EEPROM, just solder thin wires on pins (but veeeery carefuly) and read the EEPROM using PonyProg or some similar soft. If you need more details, send a post here. Regards, Dodo |
N gage keypad failure need help | eko_java_cell | Nokia Hardware & Hardware Repair | 2 | 03-17-2008 13:06 |
3650 ccserasepmm failure! need help | Gorden | Twisterflasher | 7 | 10-04-2004 01:37 |
mw 3026 Hardware failure need help!!! | chinex14 | Infineon C16X M51 & ARM7 M52 BASED | 6 | 09-22-2003 23:41 |
SAGEM 939 S5-D2 FW4.1M ? | elektron code ECS | Infineon C16X M51 & ARM7 M52 BASED | 8 | 05-10-2001 22:15 |
Sagem MC922 S5-D2 Hard.Failure. Wht to Do? | AboAli | Infineon C16X M51 & ARM7 M52 BASED | 13 | 04-11-2001 13:36 |
