Infineon C16X M51 & ARM7 M52 BASED MYxxx: MY3078, MY3026, MY3027 MWxxx: MW3052, MW3042, MW3040, MW3020, MW936, MW939, MW939, MW930, MW940, MW3026, MW3027 MCxxx: MC3000, MC959, MC950, MC940, MC939,MC936, MC932, MC912, MC850, MC825, MC820, MC922 RCxxx: RC922, RC750, RC730 WAxxx: WA3050 |
10-24-2001, 21:20 | #1 (permalink) |
Freak Poster Join Date: Mar 2001 Location: Slovakia
Member: 3835 Status: Offline Thanks Meter: 1 | How cloning Sagem phones? Thanx brinki |
10-31-2001, 22:57 | #2 (permalink) |
Freak Poster Join Date: Oct 2000 Location: Bulgaria Age: 54
Member: 2419 Status: Offline Thanks Meter: 0 | Hi, do you tree this:<br />with ponyprog upload locked.bin to phone<br />you not need to desolder eeprom just solder wires to pcb <br />(it's 100% tested by me on about 15phones)<br />when power up your phone it will show "simlocked" whitout sim card<br />connect phone to sagem doctor<br />and choose "Verify checksum"<br />on field 251 252 and 253 choose "default values"<br />then program will say that field 5250 is destroyed<br />you must enter data manualy<br />number of checksumed fields 13<br />then enter fields one by one Field 185 <br />Field 227 <br />Field 268 <br />Field 995 <br />Field 5120 <br />Field 5374 <br />Field 5375 <br />Field 16128 <br />Field 16129 <br />Field 16140 <br />Field 16141 <br />Field 16177 <br />Field 16178 and then choose correct checksum for every field look carefuly speed on wich phone is connected and if it is bigger than 2400 you must make it 2400 cause on speed which is greater than this you will have problem with checksum correction on big fields 5375 When correct every checksum phone will be locked unlock it with any program and it will work again. If your phone doesn't start try to solder flash with hot air.But be very careful cause it's not easy.You must resolder flash and in cases when phone restart or switch off. |
11-01-2001, 17:52 | #3 (permalink) |
Member: 3835 Status: Offline Thanks Meter: 1 | Which soft use for read *.bin - Sagem doctor? Which field must be read?<br />One friend told me flash ID must be the same, when ID is other, phone will be not work. Which soft use for read flash ID? Thanx brinki |
how reset or unlock phone code in sagem phones ? [ANSWERED] | djmurod86 | PolarBox 3 | 1 | 03-07-2010 13:48 |
how about Sagem Phones and other cdma LG ???? | jr astigin | Infinity-Box | 0 | 11-21-2009 17:37 |
How to update dongle cloned sagem code reader from gsmunlock? | gsmnice | ARM9 BASED M62 / M62+ | 0 | 03-08-2004 23:40 |
how to read phone Id in Sagem 922 s6? | chrisro | Infineon C16X M51 & ARM7 M52 BASED | 4 | 02-14-2002 13:01 |
How to get PHONE ID of Sagem MW30xx phones | Mehvishal | Infineon C16X M51 & ARM7 M52 BASED | 0 | 01-30-2002 08:17 |
