Infineon C16X M51 & ARM7 M52 BASED MYxxx: MY3078, MY3026, MY3027 MWxxx: MW3052, MW3042, MW3040, MW3020, MW936, MW939, MW939, MW930, MW940, MW3026, MW3027 MCxxx: MC3000, MC959, MC950, MC940, MC939,MC936, MC932, MC912, MC850, MC825, MC820, MC922 RCxxx: RC922, RC750, RC730 WAxxx: WA3050 |
08-12-2003, 08:58 | #1 (permalink) |
No Life Poster Join Date: Dec 2001 Location: [☾✫ ] Age: 58
Member: 8159 Status: Offline Thanks Meter: 98 | mw 3026 hardware failure repair test mode code soft here www.ombossmangsm.com/Sagem.zip step 1 pen soft click test mode code button,enter your phone imei ,click calculate test mode code button soft show your test mode code step 2 : click menü button and * button you ll see application go to prom press ok write/read menü than give adress 231 you ll see a number like 05 make it 00 the phone will work best regards |
08-12-2003, 09:10 | #3 (permalink) | |
Member: 8159 Status: Offline Thanks Meter: 98 | Quote:
08-18-2003, 11:19 | #9 (permalink) |
No Life Poster Join Date: May 2000 Location: Bacau, Romania Age: 50
Member: 1447 Status: Offline Thanks Meter: 97 | For this Sagem phone exist "HARDWARE FAILURE PARAM. MISSING This phone don't enter in test mode..... If you want to connect the charger, the phone is starting!!!! so the 5 volts on pin 1 don't work.... My question is....is software or hardware trouble? TNX |
08-18-2003, 19:26 | #10 (permalink) |
No Life Poster Join Date: Mar 2003 Location: Canada Age: 44
Member: 24023 Status: Offline Sonork: 100.61317 Thanks Meter: 2,630 | my be it's software problem this solution edit with sagem doctor filed 0 and chanve last 3 byte to 0 ( save original filed0) after that you can enter hot line menue piut 00 in filed 231 , restor phone and reternu to sagem doctor and wite original filed 0 reset phone ......) taht's all if this solution don't work just tel me |
08-19-2003, 06:39 | #11 (permalink) |
Member: 1447 Status: Offline Thanks Meter: 97 | No man, don't work ...I test this method first .....is for simlocked without sim... The phone don't show charging menu with horizontal progress bar.....it start automatical and say hard fail param. error ...... still need solution!!!! TNX |
08-29-2003, 05:38 | #13 (permalink) |
Member: 1447 Status: Offline Thanks Meter: 97 | No.... I recive another phone with same trouble.... I find field 995 missing inside, restore from calculation (with id, 5260 and h21 + calc tool ) but the problem remain...... If I put the phone in charger...it start in Hard fail , not in charging screen....and 5V method not working.....another field is missing or corupted in phone... Still need help..... |
10-25-2003, 01:18 | #14 (permalink) |
No Life Poster Join Date: Jan 2003 Location: Iassy Age: 59
Member: 19723 Status: Offline Thanks Meter: 359 | Hi ! You need an eeprom backup from a good MW 3026 . You will upload it with Sagem doctor and then you will have to calculate some fields (251 , 252 , 253 and 5709) .Use 30XX InfineonV2.exe" to find the ID and to calculate the fields . insert them in your phone (using hotline menu). Happy repairing !!! Bye ! |
10-25-2003, 15:31 | #15 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,568 | ... Hi ! Hi there Mr. DomnulV from Romania This problem it's a software one and it's verry easy to repair if u have some unique tool in your head aka brain. Contact me on icq and i'll tell u how to resolve this problem on your mw3026. best regards, .:hack3r2k:. |
MW 3026 Hardware failure | to_deal_with | Infineon C16X M51 & ARM7 M52 BASED | 1 | 10-14-2003 20:42 |
mw 3026 Hardware failure need help!!! | chinex14 | Infineon C16X M51 & ARM7 M52 BASED | 6 | 09-22-2003 23:41 |
mW 3026 HARDWARE FAILURE,SIM LOCKED | zoki | Infineon C16X M51 & ARM7 M52 BASED | 6 | 11-11-2002 11:50 |
mw 3026 hardware failure | Deltas | Infineon C16X M51 & ARM7 M52 BASED | 4 | 09-15-2002 03:31 |
mw 3026 hardware failure? | poki | Infineon C16X M51 & ARM7 M52 BASED | 0 | 03-07-2002 15:12 |
