Welcome to the GSM-Forum forums. You are currently viewing our boards as a guest which gives you limited access to view most discussions and access our other features. By joining our free community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join our community today! If you have any problems with the registration process or your account login, please contact contact us. |
| Register | FAQ | Donate | Forum Rules | ★. iPhone Unlock .★ | -= JTAG BOOM =- | Search | Today's Posts | Mark Forums Read |
| Infineon C16X M51 & ARM7 M52 BASED MYxxx: MY3078, MY3026, MY3027 MWxxx: MW3052, MW3042, MW3040, MW3020, MW936, MW939, MW939, MW930, MW940, MW3026, MW3027 MCxxx: MC3000, MC959, MC950, MC940, MC939,MC936, MC932, MC912, MC850, MC825, MC820, MC922 RCxxx: RC922, RC750, RC730 WAxxx: WA3050 |
| | #1 (permalink) |
| Junior Member Join Date: Jan 2012
Member: 1714171 Status: Offline Sonork: FredSonork Thanks: 3
| Hello, I have an old SAGEM MW3027 that I want to unlock (OK, let's say very old, but at least you can figure out that I do not need this unlock for commercial purpose... ).I have some difficulties to find a relevant calculator / unlocker because this phone is quite old and resources on the internet have gone, but reading on forum archive it seems it was done in the past by user on that forum ; so maybe some of you have kept the appropriate tools required to make the unlock calculation. Hope you still have these tools, or may be can you please tell me which one I could use to use nowadays... I have NO datacable and for the moment I do not intend to buy one. I have access to the sevice menu. Here are the FIELD info : Hashtable : unknown Sagem MW3027 monitormode : *22663262336 ver : DF4,51 - 260401 1553 0 : 083A23223185502039 5709 : 918D380C 253 : A972DF3EFBAE9FFD23B144D2 191 : E80A6CBA 251 : E80A6CBA 252 : E8724AF8F3720B9E6DA85BA8C6E617 5251 : 9B7261A610DF9C052D3F 16128 : 3200 5252 : A37235A06B9CCE6CB32A 16129 : 0A00 Can you please give me some support ? I would be know wich calculator you use. Thanks in advance !! |
| | #2 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Feb 2004 Location: Algeria
Member: 56090 Status: Online Thanks: 33
| If your hashtable is 21 then your codes are : locklevel 0x00 code: 28504116-82 locklevel 0x40 code: 39207269-39 Salam |
| The Following User Says Thank You to abdoune For This Useful Post: |
| | #3 (permalink) |
| Hello Abdoune ! it works ! I entered LL00 and it works fine. Thank you very much for your help ! I have 2 questions : - what should I do with LL40 ? - which calculator did you use to calculate the code. Once again thank you for your help !! |
| | #4 (permalink) |
| Well in fact if you could explain me the difference betweenn LocLevel 00 and 40. I do not find information on this on the internet. Thanks ! |
| | #5 (permalink) |
| our forum is big caverne of ali baba héhéhé spend time and search all are explained search in archive ... there's big difference between things that you found by your self and things that it comes to you by help of others anyway search for sagem Id calculator by chris922 read the help Salam |
| | #6 (permalink) |
| With all the respect I have for you I have to tell I a quite desqpointed because this calculator is the one I used in the version 4.2.2. It's maybe not the good version but was already quite difficult to find. The information that was for me unknown was the hastable, because without it you can make 13 run per mode. I get no result with any of the fast modes. Based on your answer I now know that ashtable is 21, and using that ashtable I still get no results. "calculation failed, perhaps you entered wrong data...". Yes, perhaps... still based on your answer (less than one hour after my post) I suppose you used one of the fast mode, so I won't try the 80hours mode... Also regarding archive, It is not a hazard if I come to post in that forum. I have already spend some times on it, but it is a very difficult task to find relevant information on what we can call old technologies. Internet does not have a so good memory... just try : look for "errorlevel +MW" on google : 100% of the page will be unlocking code request, and the few technical information is just diluted in these pages... one of the reason for that is : - people how knows do not answer directly but prefer answer "just look for more information" - most of the people who don't know comes on these forum at these time were in fact not interested by technologies but only by getting quickly an unlock code. - the few people who don't know but wanted to know could look for ressources available at these time, ressources that have dissapeared today... It's a pity because knowledge is not consolidated and finally lost. But as written in the beginning of my post, all this is related to old technologies, so who cares about that nowadays... OK so thanks you for the unlock code. I know that I had the right calculator but do not know why it didn't work. That's it ! Bonne chance pour la suite ! Salam Last edited by Fred1234vF; 01-26-2012 at 00:33. |
| | #7 (permalink) |
| You haven't read the archive anyway to get codes you need Id and to find Id you need calculator ,put the imei and corresponding field crypted and uncrypted field (see the help in sagem id cal by chris922) select the hashtable and appropriate calculation corresponding to your model and firmware example firme like xx4,5x the id is mostly between range 033170000000 and 033171ffffff anyway select the second calculation from 033160000000..033179ffffff to find for sure the Id Salam |
| | #8 (permalink) |
| OK so I have a better understanding of why it doesn't work : the procedure described is exactly what I did since the beginning. The problem is probably that v4.2.2 is NOT able to calculate ID for mobile 4,5. In the menu there is only reference to 3,5 models ! there must be another version but I didn't find it on the net. Alll version find are for 4,6 mobile and then need data cable to read ID by the way : - I am still interested to understand difference between errorlevel 0x00 and 0x40. - I would like to know how you proceed to make a search in the archive. only 4252 posts on Infineon C16X M51 & ARM7 M52 BASED [Archive] GSM-Forum... The only posts I read in archive before I decided to post here have been find using google... Hope you can give me a last chane and help me on these last 2 questions... ;-) |
| | #9 (permalink) | ||
| Quote:
Salam | ||
| | #11 (permalink) |
| Freak Poster ![]() ![]() ![]() ![]() Join Date: Jul 2002 Location: Czech Republic Age: 34
Member: 13439 Status: Offline Thanks: 0
| - I am still interested to understand difference between errorlevel 0x00 and 0x40. - all sagem phones use two lock levels (but if I know - there can be more levels). Phones have lock level 01 and 41. If you try decrypt (you can use Sagem PHP encrypter or old Chris sagem utils) your field 191 (or 251) you get plain value 41. If you want unlock phone you have can encrypt value 40 and crypted value write into field 191 and 251 (or convert this code to decimal and insert into simlock menu). For lock level 00 - you can encrypt value 00 and put it to 191 and 251. From encrypter.the.cz: Phone Info MODEL: MW 3027 IMEI: 33222135805029-3 Lock and unlock codes Code for level 01: 28253404-77 (new field 191/251: a867463d) Code for level 05: 28885005-53 (new field 191/251: ac2b0549) Code for level 41: 38929973-06 (new field 191/251: e80a6cba) Code for level 00: 28504116-82 (new field 191/251: a9e5d4a2) - unlock code Code for level 40: 39207269-39 (new field 191/251: e9b18b9b) - unlock code 100% working unlock All locks levels set to 00 or no restrictions Field 191 and 251: A9E5D4A2 (00 + 3 bytes checksum) Field 252: A972DF3EFBAE9EFD98C84CCA98B6AD (0000000000000000000000 + 4 bytes checksum) Field 253: A972DF3EFBAE9EFD5A074BCA (0000000000000000 + 4 bytes checksum) Field 5709: 700F4B25 (FF + 3 bytes checksum) Most used values All languages in menu: Field 185: 000000000000 Checksum: A972DF3EFBAE25DA5A074BCA98B6 European languages in menu only: Field 185: FFFFFFBC0040 Checksum: 568DC57E8324A06E3360A9F3689F 50 records in the phonebook: Field 16128: 3200 Checksum: 9B7261A610DF9C052D3F 100 records in the phonebook: Field 16128: 6400 Checksum: CD724285FC0537DF14AD 200 records in the phonebook: Field 16128: c800 Checksum: 6172329C40C943F5751C 300 records in the phonebook: Field 16128: 2c01 Checksum: 85731C4F7E065AE4C997 400 records in the phonebook: Field 16128: 9001 Checksum: 3973F559EAE9E3370D68 10 positions for SMS in the phone: Field 16129: 0a00 Checksum: A37235A06B9CCE6CB32A 20 positions for SMS in the phone: Field 16129: 1400 Checksum: BD72A0269DB41002C282 50 positions for SMS in the phone: Field 16129: 3200 Checksum: 9B7261A610DF9C052D3F 100 positions for SMS in the phone: Field 16129: 6400 Checksum: CD724285FC0537DF14AD 144 positions for SMS in the phone: Field 16129: 9000 Checksum: 397275433AFA87219690 Phone configuration (best variant for 30xx phones): Field 16140: CF0C064F88510FDCFAE7EFFFFFFFFFFFFFFFFFFFFFFFFFFF00 00000000000000 Checksum: 667EA1001CFD9CB6E7D9F2FE91EAB482A5D06F557A7B259470 206B37D77C197989096D359739F4A7 If you want more info about unlock or eeprom... ask here :-) |
| | #12 (permalink) |
| Insane Poster ![]() ![]() ![]() Join Date: Sep 2009
Member: 1120289 Status: Offline Thanks: 19
| help unlock sagem my X3-2 Phone information: 504681117223 JA3,JB: 151203 1723 Field 0: 083A25680000651756 Field 5709: Hashtable 22 Simlockdata for to: Code for monitormode: *226632623X0 X is a number from 0-9 |
| | #13 (permalink) | |
| Quote:
Salam | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
| Service Provider Lock 1-4 ? | StompSC | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 2 | 06-27-2012 11:00 |
| Help: Forgot my 6110 user lock code!! | GByte9 | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 5 | 05-10-2012 14:14 |
| my 8810 is phone locked ,can somebody please help | duyphuc | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 16 | 02-01-2012 05:18 |
| SP Lock 1&4 | dw | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 11 | 06-26-1999 06:22 |
| Need info for unliocking 2 lock (with pic microprocesors) | Tomas | Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) | 1 | 06-26-1999 01:00 |
