Infineon C16X M51 & ARM7 M52 BASED MYxxx: MY3078, MY3026, MY3027 MWxxx: MW3052, MW3042, MW3040, MW3020, MW936, MW939, MW939, MW930, MW940, MW3026, MW3027 MCxxx: MC3000, MC959, MC950, MC940, MC939,MC936, MC932, MC912, MC850, MC825, MC820, MC922 RCxxx: RC922, RC750, RC730 WAxxx: WA3050 |
10-16-2002, 15:27 | #1 (permalink) |
Freak Poster Join Date: Jun 2002 Location: sky
Member: 12495 Status: Offline Thanks Meter: 2 | whats wrong in MC922 "PB IMEi" On Display? and then my MC 922 Not Simlock Again BUT....PB IMEI whats wrongs? help me please @legija Help me |
10-16-2002, 16:09 | #2 (permalink) |
No Life Poster Join Date: Mar 2002
Member: 10175 Status: Offline Thanks Meter: 0 | Hi... What is solution from Legija? PB IMEI indicates, that tomething with your IMEI is not OK... -> Field 0 or field 1000 is not OK. As you usually cannot access field 1000 that easy, i think, your field 0 is incorrect. Try to reconstruct your original Field 0 out of the IMEI on the sticker behind the battery. You can easily make mistakes, because some older Sagems gave the IMEI Checkdigit set to 0 in field 0, even if it has an other value. For example IMEI = 33210123456789-4 But Field 0 = 083A23012143658709 and not 083A23012143658749 I think, this is in all MC Phones with firmware older than 4,1M If this is not the error, then 1) change field 0 to something 2) use sagemdr and ose the function "Change PhoneIMEI" to repair field 0 AND field 1000. If you use the original IMEI, you need not correct the checksums |
what wronge in UB ACTIVATION | nilan | Universalbox | 4 | 04-30-2009 18:01 |
What wrong in dct-4 rpl service | DYNET | A1-Services.org | 2 | 12-20-2008 10:39 |
MY N70 on O2 is sending mms on its own! whats wrong with it. | 1508 | Nokia Base Band 5 ( BB-5 ) | 5 | 07-11-2006 14:44 |
Rc815 "pb Imei" | AlphaGSM | Infineon C16X M51 & ARM7 M52 BASED | 3 | 07-12-2003 16:59 |
Sagem MC922 - only SAGEM on display | anry | Infineon C16X M51 & ARM7 M52 BASED | 2 | 12-28-2001 10:10 |
