Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Sagem > Infineon C16X M51 & ARM7 M52 BASED
  • MYxxx: MY3078, MY3026, MY3027
  • MWxxx: MW3052, MW3042, MW3040, MW3020, MW936, MW939, MW939, MW930, MW940, MW3026, MW3027
  • MCxxx: MC3000, MC959, MC950, MC940, MC939,MC936, MC932, MC912, MC850, MC825, MC820, MC922
  • RCxxx: RC922, RC750, RC730
  • WAxxx: WA3050
  • Reply
    Old 01-09-2005, 20:36   #1 (permalink)
    Member: 22586
    MY3026 Hardware Failure Mobile Blocked
    Dear Sagem Specialists,
    I have a MY3026 with "Hardware Failure Mobile Blocked" due to multiple unsuccesful code trials. The phone data are as follows:
    Firmware version: DH3,5H 130502 1145
    Field 0: 083A05083405809180
    Field 5709: F845D3E1
    HashTable: 28
    Who could give a piece of help?
    Thanks
    Mike
    Old 01-09-2005, 22:22   #2 (permalink)
    Member: 13808
    HashTable: 28
    Thanks
    Mike
    if you check the forum very well .. there are many discussions and solutions regarding this topic, all you need do is use the serach button.
    but you may consider access the hotline menu in phone, this you do twice , the first time you get "sim missing" and the second time after sim missing, you get into hotline and reset field 231 to 00, the value there now with that error is 05..
    So find out how to enter into hotline menu and try it out..
    bR
    Old 01-10-2005, 02:38   #3 (permalink)
    Member: 87130
    Smile
    to enter into full hotline menu take the sim card out and turn the phone on you then need to enter a code.
    Code for monitormode: *226632623XY X is a number from 0-9 Y is a number from 0-9.
    There is away to calculate the value for Y, I cant remmber now but you can "search" this out, also ASTU can give it to you?
    Dont forget to put * when you start to enter the code. You should be able to change just the values for X and Y until you get the correct values to enter hotline menu and reset field 231 as essojay says
    Old 01-10-2005, 12:44   #4 (permalink)
    Member: 22586
    I found the code with ASTU, to enter the Hotline menu.
    I can't find how to change fields. I browse all the menu and find no such an option.
    Mike
    Old 01-10-2005, 13:01   #5 (permalink)
    Member: 22586
    I found the way by reading older threads.
    Down Arrow and * enters the Service menu. Select Prom then Read/write then the number or the field ie 231 the value was 05. I changed to 00 and phone works fine.
    Thanks for your help.
    Mike
    Old 01-10-2005, 13:03   #6 (permalink)
    ardagul's Avatar
    Member: 7114
    in directoy menu press * it goes hotline menu
    select prom than edit 231 to 00
    (down key +*+prom+edit+231 +00)
    regards
    (right way to read old post) edited than after seen upper post
    [IMG] code is Off
    Myx-3 Hardware failure mobile blocked Ary Dieje Sousa ARM9 BASED M62 / M62+ 14 01-19-2005 11:16
    MYX5m Hardware Failure Mobile Blocked asutpbmtaraz ARM9 BASED M62 / M62+ 5 01-11-2005 09:52
    Hardware failure mobile block!!!! asiamobile Infineon C16X M51 & ARM7 M52 BASED 3 10-12-2004 13:35
    Sagem3026-Hardware failure mobile blocked snehulienka Infineon C16X M51 & ARM7 M52 BASED 2 02-01-2004 18:22
    939 hardware failure ,mobile blocked ,what to do? igor_m ARM9 BASED M62 / M62+ 1 09-27-2000 08:54
    Page generated in 0.37591 seconds with 11 queries
