Infineon C16X M51 & ARM7 M52 BASED MYxxx: MY3078, MY3026, MY3027 MWxxx: MW3052, MW3042, MW3040, MW3020, MW936, MW939, MW939, MW930, MW940, MW3026, MW3027 MCxxx: MC3000, MC959, MC950, MC940, MC939,MC936, MC932, MC912, MC850, MC825, MC820, MC922 RCxxx: RC922, RC750, RC730 WAxxx: WA3050 |
10-06-2000, 05:11 | #1 (permalink) |
No Life Poster Join Date: Nov 2000 Location: EGYPT Age: 44
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | SAGEM 922 Problem .. HELP ME ... i have problem with sagem 922 phones .. check it ..i used sagemcalculator 0.5 to unlock sagem 922 ( 2phones ) the first i get the simlock code then didnt know what to do with it to unlock phone like ( < * * < ) in ericsson .. so i tried * 6 number of imei and goto simlock and i got password so i enterd the code and ok then i tried SIM and phone worked 100%. the problem with the next one after i got the simlock code i tried the same procedures i did above but when goto simlock menu and press OK phone Shows WAIT 02:00 and countdown to 00:00 and i get ( CODE ERROR )?!?!?1 without entering anycode ... then i tried to put SIM and after getting SIMLOCK i entered * WIth simlock-code so i got WAIT 03:00 and after 00:00 phone showed " HARD Failur " SO WHATS WRONG ?? Also , i know trick to unlock 922 some versions too its say that i have to write some fields in prom to address ( 5375 ) in prom/read write menu just from ( 0 to 271 ) or somthing like that and the only numbers i can enter is (3) so how i can get this 4 numbers ( 5375 ) where ?? plz, tell me the soluton by manual not cable .. thnx |
10-06-2000, 08:05 | #2 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Sofia, Bulgaria
Member: 2188 Status: Offline Thanks Meter: 4 | Hi, I will try to help you. Where is your phone from? Is it from D2? I have the solution for it. I work with SagemDoctor1.2. Do you have this program? With it you can edit fields without problem. Best Regards, Westerna |
10-07-2000, 07:26 | #3 (permalink) |
Member: 2583 Status: Offline Sonork: 100.88702 Thanks Meter: 203 | Hi Man , Thanks for help .. az u c NOBODY ANSWER ME http://www.thoic.net/gsm/ubb/frown.gif anyway my big problem is .. i havn't cable and i can't make cable cuz no-connectros here .. i can't find any sagem accessories .. anyway i think it can repaired by Cable . only solution .. so tell me yr solution [email protected] but what i need v.much now is WHY?? WHY IT DID THAT ? and WHATS this WAIT mean ??? and how i unlocked another 922 using the same ??? .. WHYYYY .??? its my problem now to never do my fault again .. thnx |
need rx,tx,gnd details of sagem myc5-3-help me | zonetrichur | SAGEM JTAG UNLOCKER | 2 | 09-24-2008 08:14 |
Want to buy the best Sagem solution. Pls help me with a link. | alianu | ARM9 BASED M62 / M62+ | 11 | 09-11-2004 21:58 |
Sagem 922 problem | zombie | Infineon C16X M51 & ARM7 M52 BASED | 2 | 03-12-2003 02:06 |
sagem 922 problem | GSM RAJ | Infineon C16X M51 & ARM7 M52 BASED | 0 | 11-01-2002 10:00 |
PB EEPROM 3 on Sagem MC919, please help me to fix | pali | Infineon C16X M51 & ARM7 M52 BASED | 1 | 03-30-2002 19:09 |
