Infineon C16X M51 & ARM7 M52 BASED MYxxx: MY3078, MY3026, MY3027 MWxxx: MW3052, MW3042, MW3040, MW3020, MW936, MW939, MW939, MW930, MW940, MW3026, MW3027 MCxxx: MC3000, MC959, MC950, MC940, MC939,MC936, MC932, MC912, MC850, MC825, MC820, MC922 RCxxx: RC922, RC750, RC730 WAxxx: WA3050 |
10-21-2002, 11:33 | #1 (permalink) |
No Life Poster Join Date: Aug 2001 Location: Roma Age: 49
Member: 5926 Status: Offline Thanks Meter: 275 | Mw3020 3 diferent lock codes! This phone had 3 lock codes I inserted first code said "Completed" but after that shows Simlocked. I inserted second code diferent from first and said "Completed" after that shows Simlocked. I inserted third code diferend from other codes said "Completed" and after that phone finds network. Phone was simlocked on Pay T Lock network. For me is weird Anyone meet this? BR Rak|m |
10-21-2002, 11:50 | #2 (permalink) |
No Life Poster Join Date: Mar 2002
Member: 10175 Status: Offline Thanks Meter: 0 | Hi.. Can you post your field 5374? It its not present or 00, you can enter every valid code (with all lock levels) This code is only transforemd to HEX and written into field 251. And if you enter a code with locklevel, that did not unlock the phone, you need another code :-) Perhapes it would have been enough, to enter only the third unlock code... What codes (lock levels) did you enter? |
10-21-2002, 12:07 | #3 (permalink) |
Member: 5926 Status: Offline Thanks Meter: 275 | IMEI: 332221359648004 Firmware: 108392567400 DG4,5R: 1024 09-08-01 hash table 21 ID:03 31 70 F6 F4 A7 And field 5374 is EMPTY???????? is empty read with sagem doctor 0 bytes weird again this is codes 01 - 1404880969 04 - 1456997866 05 - 1472737431 All of this was good said completed after enter it one by one after third code phone was unlocked BR Rak|m Last edited by Raklm; 10-21-2002 at 12:16. |
10-21-2002, 12:28 | #4 (permalink) |
Member: 10175 Status: Offline Thanks Meter: 0 | If 5374 is empty, you can enter every code you like :-) This is OK... if you enter "1456997866" your phone will be locked again. I think, your last code would have been enough. |
10-21-2002, 12:45 | #5 (permalink) | |
Member: 5926 Status: Offline Thanks Meter: 275 | Quote:
but when I tried to enter an wrong code said incorect code and wait 1 min 2 min 3 min and when I entered correct code sai completed Rak|m | |
10-21-2002, 13:51 | #6 (permalink) |
Member: 10175 Status: Offline Thanks Meter: 0 | What do you call a wrong code? A code is a 4 Byte value converted to decimal. The 4 bytes are: 1 Byte crypted data (crypted locklevel) and 3 Byte checksum. Only, if its crypted correctly, the code is a correct code. Or did the Phone tell "Wrong Code" if you enter a well crypted code, but with the wrong locklevel? But perhapes its better not to expereiment more with a phone, where you cannot reset the unlock counter in field 231... |
HELP Sagem MW3020 ! 3 | bungle_uk | Infineon C16X M51 & ARM7 M52 BASED | 18 | 07-27-2005 10:20 |
Wrong locking code 3 times!!! | EchiDNA | S-Gold Based Phones | 0 | 10-07-2004 10:31 |
MW3020 need sim-lock solution | Baza | Infineon C16X M51 & ARM7 M52 BASED | 0 | 09-12-2004 23:26 |
Myx-3 PayT Lock code | Tadiwa | Phone Unlocking Codes & Maps | 2 | 07-31-2004 16:01 |
