Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Sagem > Infineon C16X M51 & ARM7 M52 BASED
  • MYxxx: MY3078, MY3026, MY3027
  • MWxxx: MW3052, MW3042, MW3040, MW3020, MW936, MW939, MW939, MW930, MW940, MW3026, MW3027
  • MCxxx: MC3000, MC959, MC950, MC940, MC939,MC936, MC932, MC912, MC850, MC825, MC820, MC922
  • RCxxx: RC922, RC750, RC730
  • WAxxx: WA3050
  • Reply
    Old 01-11-2010, 12:19   #1 (permalink)
    Member: 177221
    sagem mw3026 need eeprom
    Hi!
    my sagem mw3026 is dead
    Firmware: 310151922467
    Type: DF4,5F: 1922
    Date: 15-10-01
    i need a backup eeprom for smgdoc !
    Thank's
    Old 01-14-2010, 07:37   #2 (permalink)
    Member: 13439
    Originally Posted by pmar_kpj View Post
    Hi!
    Type: DF4,5F: 1922
    Date: 15-10-01
    Thank's
    It's a same firmware which you want...
    (file df45f_neznama_mw3026.bin.txt rename to df45f_neznama_mw3026.bin (gsmforum not allow upload *.bin directly))
    The Following User Says Thank You to vozice_09 For This Useful Post:
    Old 01-15-2010, 18:45   #3 (permalink)
    Member: 177221
    Hi!
    mw3026 my flashing when power is on and is imposible to connect with this phone. (is not posible to entry in hotline menu!)
    I connected only with 30xx INFINEON and I read only this field:
    Field 3 (1 bytes) 9B
    Field 19 (1 bytes) 33
    Field 140 (9 bytes) 08 29 62 01 41 01 24 91 14
    Field 171 (1 bytes) 33
    Field 196 (1 bytes) 00
    Field 197 (1 bytes) 01
    Field 201 (6 bytes) 28 00 00 00 28 00
    Field 998 (2 bytes) FF 02
    Field 4100 (10 bytes) 18 49 05 05 00 11 05 12 10 01
    Field 16148 (4 bytes) 00 00 00 00
    Field 16181 (16 bytes) 17 00 00 00 62 04 00 00 01 00 00 00 1E 15 00 00
    Field 16185 (2 bytes) 35 3F
    Field 16192 (1 bytes) 12
    Field 16203 (2 bytes) 00 05
    how reprogram the EEPROM?
    thank's
    Old 01-15-2010, 18:49   #4 (permalink)
    Member: 13439
    use sagem doctor. But you must first set speed communications to fix speed. Use astu.exe and make log. it set speed to 19200. after it start sagem doctor, choose com, set speed to 19200 and try read any field
    Old 01-15-2010, 19:03   #5 (permalink)
    Member: 177221
    sagem doctor and astu not connected with my phone!
    phone show the sagem logo and after 3 s in restarted! led's not flashing!
    only LCD!
    only 30XX InfineonV2.exe connected!
    another ideia ?
    thank's
    Old 01-17-2010, 15:32   #6 (permalink)
    Member: 177221
    I have a question:
    for model DF4, 5F length of the field 5250 must have 32 or 28 byte?
    now the phone has 32 byte in field 5250 !
    I do not know how to check the protected fields?
    5251 - 16128
    5252 - 16129
    5253 - 16140
    5254 - 16141
    5255 - 16178
    5256 - 185
    5257 - 227
    5258 - 268
    5259 - 5120
    5260 - 995
    or
    5251 - 16128
    5252 - 16129
    5253 - 16140
    5254 - 16141
    5255 - 16177
    5256 - 16178
    5257 - 185
    5258 - 227
    5259 - 268
    5260 - 5120
    5261 - 5798
    5262 - 995
    PhoneID= 0331703D85EB
    Phone information: 934561270121 DF4,5F: 151001 1922
    Field 0: 083A23033425352214
    Field 5709: AE7B402A
    Hashtable 22
    Provider: 208-01
    Thank's for any ideia!
    Old 01-17-2010, 18:20   #7 (permalink)
    Member: 13439
    Length 5250 depend on list of protected fields.
    if you want know protected fields post here field 5250.
    Old 01-17-2010, 19:10   #8 (permalink)
    Member: 177221
    this is the original eeprom get_eeprom.txt
    phone say 'sim missing' with sim.
    with this value for eeprom get_eeprom_dupa_ce_a_mers_odata.txt the phone work on single time. after restart say 'sim missing'!
    get_eeprom_17_01_2010.txt is currently eeprom value !
    the infineon say now:
    Checking the IMEI
    ...OK
    Sorry, this does not work for this phone, perhapes theres an error in field 5250
    thank's
    Old 01-18-2010, 06:29   #9 (permalink)
    Member: 13439
    Phone Info
    MODEL: MW 3026
    IMEI: 33230435253224-1
    Lock and unlock codes
    Code for level 01: 24965925-99 (new field 251: 94cefad7)
    Code for level 05: 24174769-36 (new field 251: 9017c548)
    Code for level 41: 35641207-54 (new field 251: d4702ab2)
    Code for level 00: 25057196-81 (new field 251: 955a3f81) - unlock code
    Code for level 40: 35742145-11 (new field 251: d50a2f6f) - unlock code
    100% working unlock
    All locks levels set to 00 or no restrictions
    Field 191 and 251: 955A3F81 (00 + 3 bytes checksum)
    Field 252: 95D5724D208F5F2E2E20597AD62221 (0000000000000000000000 + 4 bytes checksum)
    Field 253: 95D5724D208F5F2EAE07747A (0000000000000000 + 4 bytes checksum)
    Field 5709: 4FF897FE (FF + 3 bytes checksum)
    Old 01-18-2010, 06:29   #10 (permalink)
    Member: 13439
    List of protected fields
    5251 - 16128
    5252 - 16129
    5253 - 16140
    5254 - 16141
    5255 - 16177
    5256 - 16178
    5257 - 185
    5258 - 227
    5259 - 268
    5260 - 5120
    5261 - 5375
    5262 - 995
    Checksumed fields list: 16128, 16129, 16140, 16141, 16177, 16178, 185, 227, 268, 5120, 5375, 995
    Old 01-18-2010, 06:43   #11 (permalink)
    Member: 13439
    Checksums are OK.
    Try set field 268 to 0000 and 5259 to 95D53F815B671080AE07
    (make changes at one time - not restart after change first field)
    Old 01-23-2010, 19:17   #12 (permalink)
    Member: 177221
    I set field 268 to 0000 and 5259 to 95D53F815B671080AE07
    but not work!
    thank's!
    Old 01-24-2010, 12:40   #13 (permalink)
    ...:::::NP™:::::...'s Avatar
    Member: 1162626
    Sonork: 100.1591727
    Question
    but not work!
    thank's!
    Yes Brother any way that It not work
    Old 01-24-2010, 16:01   #14 (permalink)
    Member: 13439
    but not work!
    thank's!
    Now you need set 5375 to zeroes and remove it from protected list... tomorrow I give you info
    Old 01-25-2010, 07:20   #15 (permalink)
    Member: 13439
    make new eeprom backup and after it make this:
    set field 5250 to:
    95EA73BB19FEA436E67A6A2817114E234B79CE5B835B436895 272E967DE4C9F3
    -- it removes 5375 from protected list
    set length of field 5261 to 10 bytes and set value
    53 C5 48 15 4D 9B B3 9E F3 BE
    set field 268 to 00 00
    set 5259 to
    restart phone... send me thank you :-)
    [IMG] code is Off
    Sagem MW3026 - how to read eeprom field 0? panv Infineon C16X M51 & ARM7 M52 BASED 9 07-19-2004 13:31
    SAGEM MW3026 need help immeadiately TheMagicMan Infineon C16X M51 & ARM7 M52 BASED 3 09-23-2002 08:20
    NEED UNLOCK KODE Sagem Mw3026 RUM Phone Unlocking Codes & Maps 2 09-01-2002 13:36
    Need Code For Sagem Mw3026 venciuzunov Phone Unlocking Codes & Maps 0 09-01-2002 02:39
    I need soft by Karlo for Sagem mw3026 Sedy Infineon C16X M51 & ARM7 M52 BASED 3 01-23-2002 13:21
    Page generated in 0.40727 seconds with 12 queries
