Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Sagem > Infineon C16X M51 & ARM7 M52 BASED
  • MYxxx: MY3078, MY3026, MY3027
  • MWxxx: MW3052, MW3042, MW3040, MW3020, MW936, MW939, MW939, MW930, MW940, MW3026, MW3027
  • MCxxx: MC3000, MC959, MC950, MC940, MC939,MC936, MC932, MC912, MC850, MC825, MC820, MC922
  • RCxxx: RC922, RC750, RC730
  • WAxxx: WA3050
  • Reply
    Old 02-12-2003, 20:52   #1 (permalink)
    Member: 1191
    Thanks Meter: 103
    Sagem MW930 FF3,1T:1931 - Hardware Fai..
    i have one Sagem MW930 FF3,1T:1931 with "Hardware failure mobile blocked".
    can anybody help to repair ?
    i try to change field 268 from 0C 00 to 0C 10 but only "SIM Lock" w/o SIM. after that i put old field 268 values.
    Svetli
    Old 02-12-2003, 21:16   #2 (permalink)
    ardagul's Avatar
    Member: 7114
    Thanks Meter: 51
    This versiyon has write -read protect and you have 2 ways.
    one of them my solution with charger 5v to pin 1(% 100 working) read that topics:
    second is bootstrap 231 eraser (ı did not try now )also read that topics:
    MC922 Hardware Failure
    Sagem MC920 FM3,4C 041200 1430 with COMPLETE FORMAT
    MW930 strange problem! Help!!!!!!!
    S922 "Complete Format"
    Old 02-12-2003, 21:40   #3 (permalink)
    Member: 1191
    Thanks Meter: 103
    10x for quick answer
    Svetli
    Old 02-12-2003, 23:53   #4 (permalink)
    Member: 10175
    Search the tool 231fix this is a binary file for the bootstraptool. It resets field 231 to 00. But it is only for version FF3.1T
    Another Method is this:
    -Read the PhoneID with Bootstraptool and calculate your unlock code.
    -The last 2 digits of the code swapped (digit 8 and 7) must be the same like the second byte of field 5374 (If not, temporeraly delete field 5374, but then you have to enter the full 8 digit code later)
    -Change the last byte of field 0 to 00
    -Change field 268 to 0c 10
    -Switch your Phone off and on
    -Enter *XXXXXX00 + OK, where XXXXXX is digit 7-12 of your IMEI
    -> you can reach the Phone menue now
    -> Important: Write now with sagemdoc the original values for fields 0 and 268 to the Phone
    -> go inside the Phonemenue to "Simlock" and enter the correct unlock code. Perhapes you have to wait some time :-)
    - If you changed field 5374, correct it to the original vatue, too
    => Now your Phone should work again, if there is no other problem
    [IMG] code is Off
    MW930 FF3,4k hardware failure!! hallo Infineon C16X M51 & ARM7 M52 BASED 3 06-30-2004 09:41
    Help ! MW930, FF3.1T Hardware failure dagsm Infineon C16X M51 & ARM7 M52 BASED 0 02-17-2002 17:02
    Help,please,MW930 FF3,4K-Hardware Failure aleki Infineon C16X M51 & ARM7 M52 BASED 0 02-04-2002 11:58
    Sagem MW930 FF3.1T:1931 hardware failure solution florinmar Infineon C16X M51 & ARM7 M52 BASED 3 02-03-2002 20:44
    sagem MW930 FF3,4G rios Infineon C16X M51 & ARM7 M52 BASED 2 11-23-2001 21:59
    Page generated in 0.27267 seconds with 8 queries
