Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Sagem > Infineon C16X M51 & ARM7 M52 BASED
  • MYxxx: MY3078, MY3026, MY3027
  • MWxxx: MW3052, MW3042, MW3040, MW3020, MW936, MW939, MW939, MW930, MW940, MW3026, MW3027
  • MCxxx: MC3000, MC959, MC950, MC940, MC939,MC936, MC932, MC912, MC850, MC825, MC820, MC922
  • RCxxx: RC922, RC750, RC730
  • WAxxx: WA3050
  • Reply
    Old 07-21-2005, 06:33   #31 (permalink)
    charles njoroge's Avatar
    Member: 119127
    Originally Posted by vozice_09
    Encrypter is my work only... With Chris922 I talked last before few months...
    But if you want read it:
    THANKS TO CHRISTIANN. HE LEARNT ME VERY THINGS ABOUT SAGEM PHONES AND CO-OPERATING WITH HIM WAS VERY INTERESTING AND FUNNY :-)
    I REALLY APPRECIATE IF YOU CAN TEACH ME ABOUT SAGEM PHONES ESPECIALLY 30XX &MYX5
    Old 10-10-2005, 08:32   #32 (permalink)
    Member: 13439
    Small update:
    - added hash tables 2C, 2F, 62
    Small note:
    - if you use Hack3r2k Furisous calc - Manual calculator - hash tables 23 and 24 are bad
    Old 10-11-2005, 06:36   #33 (permalink)
    Member: 13439
    Next small update:
    - added options for detecting hash table from crypted value (normal and special crypt)
    - hash tables 13 and 14: I don't know where I get and if tables are rights. Can someone test it?
    Old 10-11-2005, 08:02   #34 (permalink)
    chiragp's Avatar
    Member: 106367
    Sonork: 100.1577436
    how to enter a code x-5 after geting code pls explain herer thnks for links
    Old 10-11-2005, 08:48   #35 (permalink)
    Member: 13439
    first step is use search button here in forum...
    Old 10-11-2005, 09:39   #36 (permalink)
    chiragp's Avatar
    Member: 106367
    Sonork: 100.1577436
    i have already try but no success thnks friend
    Old 12-01-2005, 14:13   #37 (permalink)
    Member: 13439
    Next update at http://encrypter.the.cz:
    Rebuild protected fields list 5250
    - in this mode you can create new field 5250. Simply insert field 0, ID, select hash and as data insert field numbers separated with "," (example: 16128,16129,16140,16141,16178,185,227,268,5120,995 )
    Multiple crypt/decrypt (normal and special)
    - if you want crypt/decrypt few fields in one step: as data use values separated with ",". Script crypt/decrypt all values at once. Warning: if you decrypt few values with this method - all must have same checksum length!
    Fields value compare
    - this is for lazy guys. Fill input DATA with two strings separated with ",". It's ideal for long fields as 16140. Script control length and compare these strings and return if are the same or on which position is first difference.
    Old 12-01-2005, 15:07   #38 (permalink)
    Super Moderator
    stanner_austin's Avatar
    Member: 49752
    Sonork: 100.112446
    @vozice_09
    NEED LITTLE HELP....
    I TRY IT WITH THIS LOG IT WAS CALC BY BB-GSM AT THIS FORUM....
    Phone information: 436925007081 JB3,FI: 230904 1500
    Field 0: 083A35330150895088
    Field 5709: 906A45DD
    Hashtable 22
    YOUR SITE GIVE ME THIS CODE..
    Lock and unlock codes
    Code for level 01: 10268910-04 (new field 251: 3d351cfc)
    Code for level 05: 09569819-83 (new field 251: 390a62df)
    Code for level 41: 21134564-64 (new field 251: 7df8c950)
    Code for level 00: 10182867-13 (new field 251: 3cb1d279)
    Code for level 40: 20824872-78 (new field 251: 7c203bee)
    AND THIS CODE GIVED BY BB-GSM.......
    20025660-47
    YOUR CODE WORKS?
    I ALSO UPLOADING IMAGE THAT I ENTERD ALL DATA....PLZ CHECK WHER I AM WRONG?
    Old 12-01-2005, 15:41   #39 (permalink)
    Member: 13439
    Originally Posted by stanner_austin
    @vozice_09
    20025660-47
    you are wrong... at image you swap Field 0 and ID... and is your id really 436925007081? with this combination of field 0 and ID i can not decrypt your field 5709 to plain value...
    Old 12-02-2005, 06:57   #40 (permalink)
    Super Moderator
    Member: 49752
    Sonork: 100.112446
    BUT SIR SORRY FOR THAT MISTEK....I AGAIN DO WITH RIGHT DATA.....ITS GIVING SAME CODES.....
    AND WORKING CODE IS THIS
    20025660-47
    WHERE I AM WRONG....I ENTER ONLY FIELD 0 AND ID FOR UNLOCK.......I HAVE TO ENTER FIELD 5709?
    IF YES THEN WHERE?
    Old 12-02-2005, 07:08   #41 (permalink)
    Member: 13439
    20025660-47
    IF YES THEN WHERE?
    you are atill wrong...
    If you have log like this:
    Phone information: 543102678975 JH3,BP: 230703 1755
    Field 0: 083A15750860802813
    Field 5709:
    Hashtable 22
    THIS IS NOT ID - 543102678975!!!
    You must use any calc for detect your correct id!
    Old 12-02-2005, 10:40   #42 (permalink)
    cellworld's Avatar
    Member: 53457
    @hi sir tell me which code i use for unlock mw3020
    @hi sir tell me which code i use for unlock mw3020 pleaseeeeeeee
    MODEL: MW 3020
    IMEI: 350800350xxxxx-2
    Code for level 01: 11448854-68 (new field 251: 443d90dc)
    Code for level 05: 10898675-94 (new field 251: 40f60f4a)
    Code for level 41: 007105979-871059798- (new field 251: 043c4956)
    Code for level 00: 11664805-59 (new field 251: 458714af)
    Code for level 40: 009894573-598945735- (new field 251: 05e5cac7)
    log by astu
    Phone information: 031707245386 DI4,6J: 070802 1733
    Field 0: 083A05083005385123
    Field 5709: DEB7F542
    Hashtable 21
    Simlockdata for to:
    Code for monitormode: *226632623X2 X is a number from 0-9
    phone id: FB9F31FF32D8
    thanx a lot in advance
    cellworldd
    Old 12-02-2005, 11:58   #43 (permalink)
    Member: 13439
    one cosmetic error at encrypter.. now repaired.
    Code for level 41: 00710597-98 (new field 251: 043c4956)
    Code for level 00: 11664805-59 (new field 251: 458714af) - unlock code
    Code for level 40: 00989457-35 (new field 251: 05e5cac7) - unlock code
    your firmware use in most cases lock level 01 - best way for unlock: start phone - use sagem doctor - edit eeprom field 251 - write and save value 458714af
    restart phone
    Old 12-05-2005, 06:38   #44 (permalink)
    cellworld's Avatar
    Member: 53457
    @vozice_09 hi freind thanx a lot but after unlock
    @vozice_09 hi freind thanx a lot but after unlock in phone no outgoing and no incomming call recive so tell me please what can i do pleaseeeee
    restart phone
    thanx a lot in advacnce
    celloworlddd
    Old 12-08-2005, 16:45   #45 (permalink)
    usernome's Avatar
    Member: 19723
    Can you tell me where is located field 147 on a dump from MW959 read with Ponyprog ?
    [IMG] code is Off
    ned unlock code for sagem my W-8 nokia4m Phone Unlocking Codes & Maps 2 05-03-2010 17:23
    Vodafone sagem my401v possibale to unlock ..::AppleLinks::.. FuriouS TeaM Products 1 03-29-2010 17:28
    How to encrypt files on windows mobile with File Encryption software wmkin HTC & PDA WM( With Touchscreen) 0 02-16-2010 02:01
    Encrypt files on Windows Mobile - WMkits File Encryption wmkin HTC & PDA WM( With Touchscreen) 1 02-09-2010 02:40
    Reversing the algo's used for encrypting the IMEI papajoe GSM Programming & Reverse Engineering 31 07-14-2002 07:14
    Page generated in 1.29984 seconds with 11 queries
