Infineon C16X M51 & ARM7 M52 BASED MYxxx: MY3078, MY3026, MY3027 MWxxx: MW3052, MW3042, MW3040, MW3020, MW936, MW939, MW939, MW930, MW940, MW3026, MW3027 MCxxx: MC3000, MC959, MC950, MC940, MC939,MC936, MC932, MC912, MC850, MC825, MC820, MC922 RCxxx: RC922, RC750, RC730 WAxxx: WA3050 |
08-11-2001, 19:06 | #1 (permalink) |
VIP-Member Join Date: Feb 2001 Location: any where Age: 55
Member: 3222 Status: Offline Thanks Meter: 86 | Unlock solution for MW 930 FF3,1T There are 2 solutions !!<br />You need sagemdr to edit the fields. <a href="http://de.geocities.com/wazl2002/sagdr32.zip" target="_blank">Sagem Dr.</a> First check field 5253. If this field is 10 bytes long than use solution 1.<br />If this field is 40 bytes long than use solution 2.<br />Both solutions are tested by myself and it works 100 % !!!!!! Solution 1:<br />--------------- 1. write field 268 into field 12. Field 12 must cut to 2 bytes<br />2. write field 5253 into field 5250. Field 5250 must cut to 10 bytes<br />3. write field 5253 into field 5251. Field 5251 must cut to 10 bytes<br />4. change field 5375: 01 01 00 00 00 00 xx xx xx xx xx xx FF FF FF....<br />xx must be FF !! <br />Solution 2:<br />--------------- 1. write field 268 into field 12. Field 12 must cut to 2 bytes<br />2. write field 5259 into field 5250. Field 5250 must cut to 10 bytes<br />3. write field 5259 into field 5251. Field 5251 must cut to 10 bytes<br />4. change field 5375: 01 01 00 00 00 00 xx xx xx xx xx xx FF FF FF....<br />xx must be FF !! <br />Your phone will be 100% unlocked now !!! <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> <img src="biggrin.gif" border="0"> With solution 2 i have unlock also a MC 930 4,1M S7-D2 !!! <br />Good luck to all <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> <img src="smile.gif" border="0"> wazl [ 12 August 2001: Message edited by: wazl ]</p> |
08-11-2001, 19:59 | #2 (permalink) |
No Life Poster Join Date: Feb 2001 Location: ITALY Age: 51
Member: 3381 Status: Offline Thanks Meter: 1,171 | Hi Wazl only one question my phone MW930 FF3,1 the counter for enter the unlock code is locked because i have try to enter wrong code for five times.............you have solution?<br />Tanks <img src="wink.gif" border="0"> |
08-11-2001, 21:35 | #3 (permalink) |
Freak Poster Join Date: Sep 2000 Location: Slovenia, EU Age: 59
Member: 2202 Status: Offline Thanks Meter: 0 | I have one MC 939 FW4,0V S7-D2...solution whit 268->12, 5253->... not work because you can't read field 5253, 5259, etc.<br />Sagemdoctor report error:<br />Flash read faild:invalid command code.Aborted... Any solution for this phone? Regards, Marian |
08-11-2001, 22:17 | #4 (permalink) |
Insane Poster Join Date: Mar 2001 Location: Bosnia & Herzegovina Age: 44
Member: 3677 Status: Offline Thanks Meter: 0 | I've just tried this solution with MW936 FF3.1O and result is "Sim locked" <img src="frown.gif" border="0"> Is there any other solution for this version? Regards!!! otrov |
08-12-2001, 11:49 | #5 (permalink) |
Member: 3222 Status: Offline Thanks Meter: 86 | Hi all,<br />i have test this solution only with MW 930 and i unlocked a MC 930 4,1M.<br />The second solution should work on MC 9XX but only version 4,1M but i havenīt test it. Try it and you will find out. But donīt forget to make a backup so the phone isnīt damaged if<br />somethings going wrong !!! To mtelko,<br />i think your cable is wrong or there is something wrong with your phone.<br />If you canīt read any field your connection isnīt right !!! Greetings <img src="smile.gif" border="0"> wazl |
08-12-2001, 12:01 | #6 (permalink) |
Member: 3222 Status: Offline Thanks Meter: 86 | To Pandemonio100,<br />i donīt know any cable solution for permanent blocked phone. The field is write protected !!!<br />You canīt reset it with a cable.<br />The only solution i know is desolder eeprom and program it direct. Donīt ask me more about eeprom<br />solutions because i have no experience with it.<br />I donīt want open a phone and solder inside because itīs difficult and the chance to damaged<br />phone is high !!! wazl |
08-13-2001, 09:53 | #7 (permalink) |
Member: 2202 Status: Offline Thanks Meter: 0 | I can read all field, but not 94, 251, 5250, 5251, ... Regards, Marian [quote]Originally posted by wazl:<br /><strong>Hi all,<br />To mtelko,<br />i think your cable is wrong or there is something wrong with your phone.<br />If you canīt read any field your connection isnīt right !!! Greetings <img src="smile.gif" border="0"> wazl</strong><hr></blockquote> |
08-14-2001, 22:55 | #8 (permalink) |
No Life Poster Join Date: Sep 2000 Location: Honolulu
Member: 2176 Status: Offline Thanks Meter: 1 | Hi<br />i have this prob. too<br />D2-Sagem 939 FW4.1K SIM locked<br /> <img src="mad.gif" border="0"> <img src="mad.gif" border="0"> <img src="mad.gif" border="0"> <br />i am test more software,result- <img src="rolleyes.gif" border="0"> <img src="rolleyes.gif" border="0"> <img src="rolleyes.gif" border="0"> |
08-16-2001, 00:07 | #13 (permalink) |
Freak Poster Join Date: May 2000 Location: Ukraine
Member: 1342 Status: Offline Thanks Meter: 0 | To Wazl. I've just checked both your methods for some phones MW930 FF3.1T S1-D2 - it works 100%! Thank you very much! What about reset counter problem in these phones? [ 16 August 2001: Message edited by: Jurik ]</p> |
08-16-2001, 10:08 | #14 (permalink) |
Registered User Join Date: Jun 2001 Location: x
Member: 4989 Status: Offline Thanks Meter: 13 | I've had yesterday a mw 930 FF3.1T from One (Austria) but i couldn't unlock it with any solution because field 5375 was empty !!!!!<br />What solution should I use to unlock this phone ?????????????? |
Sagem MW 930 FF3,1T Hard.. Failure | Velko | Infineon C16X M51 & ARM7 M52 BASED | 16 | 12-09-2003 21:34 |
MW 930 FF3,1T S2-D2 | antonello | Infineon C16X M51 & ARM7 M52 BASED | 3 | 01-07-2002 15:57 |
Need unlock for MW-930 FF3,1T | ejakopec | Infineon C16X M51 & ARM7 M52 BASED | 0 | 09-15-2001 20:53 |
MW 930 FF3,1T VODAFONE | jonwillow | Infineon C16X M51 & ARM7 M52 BASED | 0 | 08-23-2001 11:43 |
Sagem MW 930 FF3,1T | ceedee | Infineon C16X M51 & ARM7 M52 BASED | 2 | 08-03-2001 19:36 |
