ARM9 BASED M62 / M62+ All MYxxx Like: MY C3-2, MY X1-2, MY Z-55, MY X2-2, MY C-4, MY Z-3, MY C2-2,
MY V-75, MY X3-2, MY X-7, MY V-65, MY C-1, MY X-1w, MY C-6, MY C-5w, MY C-2, MY
X-2, MY X-6, MY G5, MY X-3, MY X-5, MW X1, MY V-56, VS2, VS1, MY C5-2, MY X-8,
MY X-4, MY C4-2, MY V-55, MY X5-2, MY C-3b, MY C-3s,MY100, MY200, MY300X, MY400, MY V-85, MY V-76,
MY X6-2 etc Also SG321i, VS3 & MY-S7 (Smart Phone) |
12-15-2004, 22:54 | #1 (permalink) |
Freak Poster Join Date: Nov 2004 Location: Crawley - West Sussex UK Age: 59
Member: 92770 Status: Offline Thanks Meter: 1 | Sagem CDR V 14.0 & myX-1 BAD CONNECTION? Any one else have this issue? This is really doing my head in, some help or any known issues thatmaybe I should know. Steps I Do: Select myX-1 Power on phone Read code Then the progress bar goes across quite quick at bottom then says ERROR: Bad Connetion Help |
12-16-2004, 00:46 | #4 (permalink) | |
Member: 92770 Status: Offline Thanks Meter: 1 | Quote:
Also have tried other good cables that I know work. I thought it was a case of just connecting cable to myx-1 What do you mean about test points on myx-1 | |
12-16-2004, 00:58 | #5 (permalink) |
Freak Poster Join Date: Oct 2003 Location: GSM Center Ro ******** Age: 44
Member: 41900 Status: Offline Thanks Meter: 2 | I had the same problem, i solved very easy. selected another type of phone in software, so try myx 2- myx3..... etc. One will work, nothing happend don't worry it is only a reader. You have nothing to lose, do as I say. You' ll see.... it will work, believe me |
12-16-2004, 01:07 | #6 (permalink) | |
Could this be a cable Issue, as in dodgy? Cheers | |
12-16-2004, 01:10 | #7 (permalink) | |
Member: 41900 Status: Offline Thanks Meter: 2 | Quote:
If this doesn't work you must find out if this the phone or the box | |
12-16-2004, 01:28 | #8 (permalink) |
No Life Poster Join Date: Jun 2002 Location: UK/Espaņa Age: 54
Member: 12578 Status: Offline Thanks Meter: 60 | After pressing DO JOB, try to unplug the data plug from the bottom of handset and plug back in.......I have had a few that do this and the reader then gives code in about 3-4 seconds!! |
12-16-2004, 01:45 | #9 (permalink) |
No Life Poster Join Date: Feb 2004 Location: ROMANIA Age: 46
Member: 55427 Status: Offline Thanks Meter: 7 | To find out if is box deffect try to connect 3026 infineon, because u don`t need test point to this model and if phone connects then box is good and u have test point problem (inverted cables or intrerupted tracks). B R, xyz |
12-16-2004, 05:14 | #10 (permalink) | ||
So is this then a duff, bad dodgy cable? | ||
12-16-2004, 05:22 | #11 (permalink) |
Member: 92770 Status: Offline Thanks Meter: 1 | Ok Just a thought the USB power cable to the box is connected to another pc would this have any adverse effect? As im using an old 98se system with no usb, so usb is connected as stated to another machine. |
12-16-2004, 06:03 | #14 (permalink) | |
Huh I use 10_12_13 & none of the versions work; Same error will read then bad connection! | |
V5.0 & V5.1 Working Now! Problem Solved! | RoDNoc | Motorola P2K (USB-Smart) | 20 | 07-16-2006 19:13 |
myx-1w bad connection | Mehvishal | SwS_SaG_BoX | 8 | 04-13-2006 19:37 |
Need Help Sagem Cdr V.14 | sealcom | Infineon C16X M51 & ARM7 M52 BASED | 6 | 03-31-2006 18:35 |
CDR 10.1 - Bad Connection | sagemák | ARM9 BASED M62 / M62+ | 0 | 02-04-2004 15:15 |
Andromeda 4.0 & 4.1 | Erik | Alcatel & TCL Old Models | 2 | 03-08-2000 13:59 |
