| ARM9 BASED M62 / M62+ All MYxxx Like: MY C3-2, MY X1-2, MY Z-55, MY X2-2, MY C-4, MY Z-3, MY C2-2,
MY V-75, MY X3-2, MY X-7, MY V-65, MY C-1, MY X-1w, MY C-6, MY C-5w, MY C-2, MY
X-2, MY X-6, MY G5, MY X-3, MY X-5, MW X1, MY V-56, VS2, VS1, MY C5-2, MY X-8,
MY X-4, MY C4-2, MY V-55, MY X5-2, MY C-3b, MY C-3s,MY100, MY200, MY300X, MY400, MY V-85, MY V-76,
MY X6-2 etc Also SG321i, VS3 & MY-S7 (Smart Phone) |
| | #1 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Nov 2002 Location: Canary Islands Age: 39
Member: 17351 Status: Offline Thanks: 12
| Sagem MyV-65 screen dead after trying to unlock with the CDR V14. I soldered the testpoints as per the photo. It wouldnt unlock just said bad connection. Now I have put the phone back together and the screen has gone? |
| | #2 (permalink) | |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2003 Location: england Age: 51
Member: 24552 Status: Offline Thanks: 2
| Quote:
| | #4 (permalink) |
| Looks like the screen has gone! Have cleaned it. Am either getting a white screen or half screen then it is going all over the place |
| | #7 (permalink) | |
| Product Manager ![]() ![]() ![]() ![]() ![]() Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks: 65
| Quote:
Br | |
| | #9 (permalink) |
| Product Supporter ![]() ![]() ![]() Join Date: Mar 2003 Location: Micro-Box on Tunisia 98292606 Age: 30
Member: 24023 Status: Offline Sonork: 100.61317 Thanks: 19
| i belive flash can't do nothing for this mobiles problem in V65 and X6 samthind bad solder pin result LCD don't work see my old post and you will understand |
| | #10 (permalink) |
| No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Apr 2004 Age: 34
Member: 61294 Status: Offline Thanks: 0
| wrong application on your LCD, would allows " bad connection". 2. adjust your phone flexi, before anything. 3.try your phone with another LCD. 4.if all application, are applied,before you can reflash, your phone. ****************bestman*********************** |
| | #11 (permalink) |
| Its nothing to do with flash I took the screen out applied the 4 testpoints and then it said bad connection. I re-soldered but still the same. After about an hour messing about I decided that It would not unlock. So I put the screen back in pushed it right up and now it is either a white screen or one like an 8210 with a dodgy elaastomer. For some unexplainable reason the screen is now damaged. It is not the software for sure 100% @Hibititi i have looked through your old posts but cant find the one you are referring to!? |
| | #12 (permalink) | |
| Quote:
| | #13 (permalink) | |
| Junior Member ![]() Join Date: May 2004 Age: 44
Member: 64278 Status: Offline Thanks: 0
| Quote:
============== reply from alan alan@fone-post.com I done the same and found that after i refit the screen it come with white light or did not come on i fix it by pushing the ribbon connector down with out the screen ribbon in And then i slided it into the conector | |
| Bookmarks |
| Thread Tools | |
| Display Modes | |
