Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Sagem > ARM9 BASED M62 / M62+
ARM9 BASED M62 / M62+ All MYxxx Like: MY C3-2, MY X1-2, MY Z-55, MY X2-2, MY C-4, MY Z-3, MY C2-2, MY V-75, MY X3-2, MY X-7, MY V-65, MY C-1, MY X-1w, MY C-6, MY C-5w, MY C-2, MY X-2, MY X-6, MY G5, MY X-3, MY X-5, MW X1, MY V-56, VS2, VS1, MY C5-2, MY X-8, MY X-4, MY C4-2, MY V-55, MY X5-2, MY C-3b, MY C-3s,MY100, MY200, MY300X, MY400, MY V-85, MY V-76, MY X6-2 etc
Also SG321i, VS3 & MY-S7 (Smart Phone)
Old 03-02-2004, 20:13   #1 (permalink)
tical's Avatar
Member: 43802
Sagem Terms Explained
Hi, I am trying to get a handle on how to unlock Sagems, but would like to first know the territory. my questions are
1. What is a lock level ? apparently you phone can be locked to more than one, and how do you know which locklevel your phone is locked to ?
2. What is the PhoneID ? is it the unlock code ?
3. What fields are needed to fully calculate an unlock code ?
Old 03-02-2004, 20:29   #2 (permalink)
Member: 56090
Hello Tical am also newbee but i can give you some help perhaps it interest you ...
The fields needed to calculate an unlock code are:
field 5250 to 5262 you can obtain there value by entering to hotmenu by pressing:
IN sagem 3xxx: *226632623xy where y
DJ3,5C a DJ3,5D a DJ3,5E a DH3,5H : y=5
DF4,5E a DF4,5F a DH4,6J a DJ4,6G a DG4,5H a DI4,6G : y=4
JC3,6N a JC3,6O a JC3,6L : y=2
and x egal the additional four number
for exemple if the IMEI is :35074635261245-3
1245 -> 1+2+4+5 = 12
12/10 =2 , x=2
Is it ok , i wish my help will be usefull, best regards.
Old 03-02-2004, 21:49   #3 (permalink)
tical's Avatar
Member: 43802
Thank you
All help is appreciated.
Old 03-03-2004, 08:18   #4 (permalink)
Member: 56478
Are there some phones that cannot enter hot menu, i tried that in my sagem myx-2 but nothing is working i have substitute x btn 0-9 but still not entering hot menu. any suggestions
Old 03-03-2004, 17:17   #5 (permalink)
Member: 56648
I have the same problem. I'm trying to enter the hotline menu with the code but it won't work. I'm using an my-X5. I could use some help aswell!
Old 03-03-2004, 18:17   #6 (permalink)
tical's Avatar
Member: 43802
Same Problem with My-x2a
I guess the solution is to unlock it via the server ?
Old 03-04-2004, 06:25   #7 (permalink)
Member: 56478
Hi ripcord seems ur having same problem like i had (cannot enter hot menu)was forced to unlock mine online www.freefonefun.net log costs £9.98, u may also temporarily use phone by entering the blocked simcard then **05* it will ask for PUK which u input, enter new pin (could b same one as b4). this procedure works till u switch of phone then u have to repeat the step again.
Old 03-04-2004, 09:39   #8 (permalink)
Member: 56648
Hi cmwangi, would it not have been easier to get a data cable and read these "EPROM" stuff from the phone? In this forum, you seem to be able to get the unlock codes for free if you have the info? That's what i'm thinking of doing!
Old 03-05-2004, 06:31   #9 (permalink)
Member: 56478
Free?
in this forum, u nid field 0, 5709 --> data cable by itself cannot read the fields
dongle costs money but try this software http://free-zg.htnet.hr/hrco/astu.zip to retrieve the above fields then post them in forum or use calculator.
Old 03-05-2004, 06:33   #10 (permalink)
Member: 56478
Smile Free?
in this forum, u seem to nid field 0, 5709 --> data cable by itself cannot read the fields dongle costs money but try this software http://free-zg.htnet.hr/hrco/astu.zip to retrieve the above fields then post them in forum or use calculator.
Old 03-05-2004, 10:59   #11 (permalink)
Member: 56648
Where could I get this "calculator" your talking about?
Old 03-08-2004, 12:35   #12 (permalink)
Member: 49834
Between newbees we help at each other
So,
1 - The locklevel : determines which sort of locking method your phone has (0x40 for unblocked, 0x00 for never blocked, etc.)
2 - PhoneID : It's the phone IDentification number. It is not the unlock code =). That's from this ID that all the fields are crypted / encoded in the eeprom. That's why some toolz can reverse the calculation to retrieve this ID from 2 fields (one crypted, the other uncrypted). For some versions of firmware (xx4,6X) the ID MUST be retrieved with a datacable and with a special tool.
3 - The fields needed : the field 0 (IMEI in a twisted form) and the PhoneID are only required by example if you use the the tool SRSv1.2 from Chris922. In any case you will be asked to enter these two fields. They are mandatory. Also the Hash Table (depends on phone model) is required.
That's what i've learned here ! Hope it will help you !
Old 03-10-2004, 19:10   #13 (permalink)
REPAIRMAN's Avatar
Member: 5831
Can anyone tell me is the Field 5709 crypted,
& if so what is the Field location for the same uncrypted data.
Regards
Old 03-11-2004, 19:20   #14 (permalink)
tical's Avatar
Member: 43802
There's gotta be a better way
Hi, I used the SAGEM v 2.3 to calculate the code for a MY-X5 , my PC is 400 Mhz cpu, Using fast method, nothing happen, with Slow method , it took 4 Hrs to return the code !!!. Now from a business point a view , I would get a lot of grey hairs before I made any money off Sagems at this rate.
I am assuming that there is some other method that can calculate the codes quickly.
Old 03-12-2004, 17:06   #15 (permalink)
Member: 49834
Hello,
it seems there is no field corresponding with 5709. Perhaps you can use it as uncrypted and crypted field.
This field is required in case you can't enter into the monitor mode... I can't tell you more about it because I don't know more, sorry !
[IMG] code is Off
ned unlock code for sagem my W-8 nokia4m Phone Unlocking Codes & Maps 2 05-03-2010 17:23
Alcatel Hd1 - "Code Term." s.Mobi Alcatel & TCL Old Models 9 02-24-2002 17:06
Questions about the terms being used... starhunta Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 1 12-24-2001 21:26
What are the terms to join the vip area? Bolo Old Ericsson Phones & Sony Phones 0 04-10-2000 13:58
Page generated in 0.39229 seconds with 11 queries
