ARM9 BASED M62 / M62+ All MYxxx Like: MY C3-2, MY X1-2, MY Z-55, MY X2-2, MY C-4, MY Z-3, MY C2-2,
MY V-75, MY X3-2, MY X-7, MY V-65, MY C-1, MY X-1w, MY C-6, MY C-5w, MY C-2, MY
X-2, MY X-6, MY G5, MY X-3, MY X-5, MW X1, MY V-56, VS2, VS1, MY C5-2, MY X-8,
MY X-4, MY C4-2, MY V-55, MY X5-2, MY C-3b, MY C-3s,MY100, MY200, MY300X, MY400, MY V-85, MY V-76,
MY X6-2 etc Also SG321i, VS3 & MY-S7 (Smart Phone) |
09-18-2003, 19:16 | #1 (permalink) |
Junior Member Join Date: Sep 2003
Member: 39582 Status: Offline Thanks Meter: 0 | Upgrade MYX-3 to MYX-3d failed. Will get my baby runnin' again... Removed the akku and switched it on again - now the phone shows 'SIM locked'. Oh s*#t! Does I have a chance to get it it running again with a data cable (which I don't have yet, also no eeprom backup) and the appropriate tools? What are the steps to keep it running again if possible? Thank you in advance. -dgs - |
09-18-2003, 19:28 | #2 (permalink) |
Product Manager Join Date: Aug 2002 Location: FuriouSTeaM
Member: 15022 Status: Offline Sonork: 100.53452 Thanks Meter: 61,567 | ... Hi ! Smart move that a newbie to f*uck around with X3 phones OK..man pray to G O D and contact me ... If the test mode does not work on your phone then don't bother to contact me cause the other way to do that is secret and secret will remain so ... ICQ: #157715181 best regards, .:hack3r2k:. |
09-19-2003, 18:04 | #4 (permalink) |
Member: 39582 Status: Offline Thanks Meter: 0 | ... @pitone02, do you mean, I should change all bytes I've flipped in field 16140 from 0xFF to 0x00 back to 0xFF with SagemDoctor? Then the phone will work again? Hope that the rest of 16140 which wasn't 0xFF didn't changed during reboot of phone through some firmware magic. I have no record of the old values. :-( But at first I have to wait for the data cable and use my old (but working) Mars Trium instead... Yesterday I was bursting with curiosity whats 'inside' the X3 (no backup, no data cable, no written down numbers...), now I left 'outside.' Hi Newbies, don't make the same way like me. Try to be on safe side before you change or modify something and don't rely on a working phone for some time. Thank you, -dgs |
09-22-2003, 08:01 | #5 (permalink) |
No Life Poster Join Date: Jul 2002
Member: 13999 Status: Offline Thanks Meter: 74 | in the posy started by me....the sequence of operation is simple. it is written "backup your old value before make change" you must restore your old value if you want your phone works. read it (field 16140) from another phone of same provider and try to write it to your phone....if you are lucky....phone works again |
trying to get my iphone working again | branm80 | iPhone 2 / iPhone 3G / iPhone 3GS | 1 | 09-21-2009 01:51 |
When I will get my dongles | Solutions13 | FuriouS II | 17 | 04-20-2005 14:56 |
is myx-3d differend myx-3 ??????? | cep_man | ARM9 BASED M62 / M62+ | 2 | 01-15-2005 16:55 |
Upgrade MYX-3 to MYX-3d | pitone02 | ARM9 BASED M62 / M62+ | 30 | 07-16-2003 12:00 |
