Wonu With Sws-sag 2 Attachment(s) i have a seiously problem with wonu phone it's not working with me . it's blocked when he have 70% in program. i'mtrying all test point available! please help me!!! |
check cable using scheme from support section of sws-sag.com |
i try all the shema's in the support area but it's not working! pls if u have a working test point and shema cable give it to me!! |
Try to push on your testpoints with one finger while reading. |
@farfour: we use TP PCB JTAG so it's not solderign etc. but I thin that boulogne give you good hint - try it and if you don;'t have any results conatct with us PM so I will give you link wherr you can buy prffeional JTAG (not China made TP where pins are 2mm from location where it schodul be) |
work for me but don't show phone code!!only nck!! |
Yes, phone code is a pb with this phone. No solution found. :( |
to unlock wonu, use only sws-sag 1.4 - b.r |
I don't try this because we never see Wonu phones here in the UK ;) br |
try to use it in win98 ,not XP...:) works 100%.;) |
furiouus can't too Quote:
but for phnoe code can't reead,and can't reset. i made i a serial cable. 5 --- gnd 14---tx 15---rx |
with sws-sag it's not work i try all the shma'sand test point ! it found a phone and stop operation in 70% with blocking telephone!!! |
scdr2 is the best it can give you security code but in sws no wonu read code only 1.4 version dont work with last update stop at 70% |
i tested the scdr2 & sws but scdr2 is the better for all sagem |
but my box sws is not working with 1.4 when i launch the program it give me this message: key not found |
