Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Sagem > ARM9 BASED M62 / M62+
ARM9 BASED M62 / M62+ All MYxxx Like: MY C3-2, MY X1-2, MY Z-55, MY X2-2, MY C-4, MY Z-3, MY C2-2, MY V-75, MY X3-2, MY X-7, MY V-65, MY C-1, MY X-1w, MY C-6, MY C-5w, MY C-2, MY X-2, MY X-6, MY G5, MY X-3, MY X-5, MW X1, MY V-56, VS2, VS1, MY C5-2, MY X-8, MY X-4, MY C4-2, MY V-55, MY X5-2, MY C-3b, MY C-3s,MY100, MY200, MY300X, MY400, MY V-85, MY V-76, MY X6-2 etc
Also SG321i, VS3 & MY-S7 (Smart Phone)
Old 04-04-2005, 16:10   #1 (permalink)
Member: 111730
Thanks Meter: 116
Wonu With Sws-sag
i have a seiously problem with wonu phone it's not working with me .
it's blocked when he have 70% in program.
i'mtrying all test point available!
please help me!!!
Old 04-04-2005, 21:30   #2 (permalink)
Multi-COM's Avatar
Member: 43823
Sonork: 100.79167
Thanks Meter: 296
check cable using scheme from support section of sws-sag.com
Old 04-05-2005, 17:02   #3 (permalink)
Member: 111730
Thanks Meter: 116
i try all the shema's in the support area but it's not working!
pls if u have a working test point and shema cable give it to me!!
Old 04-05-2005, 17:16   #4 (permalink)
boulogne's Avatar
Member: 18301
Thanks Meter: 3
Try to push on your testpoints with one finger while reading.
Old 04-05-2005, 19:59   #5 (permalink)
Multi-COM's Avatar
Member: 43823
Sonork: 100.79167
Thanks Meter: 296
@farfour: we use TP PCB JTAG so it's not solderign etc. but I thin that boulogne give you good hint - try it and if you don;'t have any results conatct with us PM so I will give you link wherr you can buy prffeional JTAG (not China made TP where pins are 2mm from location where it schodul be)
Old 04-08-2005, 18:00   #6 (permalink)
street's Avatar
Member: 24284
Thanks Meter: 51
work for me but don't show phone code!!only nck!!
Old 04-08-2005, 18:04   #7 (permalink)
boulogne's Avatar
Member: 18301
Thanks Meter: 3
Yes, phone code is a pb with this phone.
No solution found.
Old 04-08-2005, 19:17   #8 (permalink)
kasketm's Avatar
Member: 17451
Thanks Meter: 31
please help me!!!
to unlock wonu, use only sws-sag 1.4 -
b.r
Old 04-08-2005, 21:23   #9 (permalink)
bungle_uk's Avatar
Member: 51154
Thanks Meter: 68
No solution found.
Try to read user code with Furious software, go to Bootstrap Communication, press Connect, then Phone Code Read.
I don't try this because we never see Wonu phones here in the UK
br
Old 04-08-2005, 23:54   #10 (permalink)
xchris's Avatar
Member: 8490
Thanks Meter: 23
try to use it in win98 ,not XP...
works 100%.
Old 04-09-2005, 12:35   #11 (permalink)
street's Avatar
Member: 24284
Thanks Meter: 51
Red face furiouus can't too
br
i've try with furious before,i press connect prog say ok
but for phnoe code can't reead,and can't reset.
i made i a serial cable.
5 --- gnd
14---tx
15---rx
Old 04-09-2005, 13:02   #12 (permalink)
Member: 111730
Thanks Meter: 116
Thumbs down
with sws-sag it's not work i try all the shma'sand test point !
it found a phone and stop operation in 70% with blocking telephone!!!
Old 04-09-2005, 14:16   #13 (permalink)
ami_nezzar's Avatar
Member: 65050
Thanks Meter: 10
scdr2 is the best it can give you security code but in sws no wonu read code only 1.4 version dont work with last update stop at 70%
Old 04-09-2005, 14:51   #14 (permalink)
zinoubinabil's Avatar
Member: 84268
Sonork: 100.114149
Thanks Meter: 2,568
i tested the scdr2 & sws but scdr2 is the better
for all sagem
Old 04-09-2005, 14:53   #15 (permalink)
Member: 111730
Thanks Meter: 116
but my box sws is not working with 1.4 when i launch the program it give me this message:
key not found
[IMG] code is Off
Strange problem with MYX5-2T not all networks are working after unlock with sws-sag lobalt ARM9 BASED M62 / M62+ 11 11-21-2005 23:47
Sagem MY-V55 dead after direct unlock with sws-sag 1.5 jean' ARM9 BASED M62 / M62+ 41 08-18-2005 13:02
Strange problem with MYX5 not all networks are working after unlock with sws-sag lobalt ARM9 BASED M62 / M62+ 8 06-20-2005 21:53
Myx5 Dead With Sws Sag lobalt Redbox 5 06-19-2005 18:05
I NEED HELP WITH SWS-SAG BOX "BAD CONNECTION" jerrel_s Redbox 5 05-23-2005 15:23
Page generated in 0.42947 seconds with 9 queries
