Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > Siemens Hardware Repair Area
Siemens Hardware Repair Area all about Hardware Repairing you can get if here.
Old 08-04-2004, 11:54   #1 (permalink)
fabian's Avatar
Member: 27330
A52 can"t connect with Freya but can switch on
I have an A 52 phone locked,but can"t conected(please power on...)when I push the button, the soft not detects my phone and phone not switch on.If I disconect it,phone can power on.The cable was tested,is OK.
I resoldering CPU,flash,Dialog,RAM and the small ics in front of charger conector.Any ideea?
Old 08-04-2004, 12:02   #2 (permalink)
steva's Avatar
Member: 4772
are you using test point?
regards
Old 08-04-2004, 12:21   #3 (permalink)
fabian's Avatar
Member: 27330
regards
the phone is under sw11,but the problem is other.Software not detect my phone.Without testpoint must write "bootcore not accepted or somethink like that.thx anyway
Old 08-04-2004, 12:37   #4 (permalink)
steva's Avatar
Member: 4772
a52 no version 11 last version is 09 and for that sw must use test point
regards
Old 08-04-2004, 12:40   #5 (permalink)
steva's Avatar
Member: 4772
my example:
i write full flash from a50 in working a55 and phone is dead.freia said pleace phone on and phone not powered and I cut test point and flash phone with orginal flash and phone work good
Old 08-04-2004, 13:45   #6 (permalink)
fabian's Avatar
Member: 27330
my example:
I"ll try,thx very much
Old 08-27-2004, 18:52   #7 (permalink)
YamahaR1's Avatar
Member: 9698
Use 3V on max232 not 5V. I use a home build max232 multi cable box with 5V or 3V switch, also handy with Philips phones.
Old 08-30-2005, 12:58   #8 (permalink)
Member: 127357
u can using whit test point martich 2
5200 connect with jaf but not able to connect with mxkey rakesh15 MXKEY Nokia Flasher and Unlocker (by Alim Hape) 6 09-13-2009 15:23
3650 can switch on but unconected with everybox Dwink@ WD2 & APE (Symbian Phones) 1 09-15-2006 10:06
3310/8250 can't on with batt but can turn on with flasher TokeiLampin Nokia Hardware & Hardware-Repair Area 14 08-05-2005 06:00
8250 can't on with batt but can turn on with flasher TokeiLampin Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 3 06-02-2005 01:08
3310 can't on with batt but can turn on with flasher TokeiLampin Nokia Legacy Phones ( DCT-1 , DCT-2 , DCT-3 , DCT-L ) 9 05-28-2005 12:36
Page generated in 0.27837 seconds with 11 queries
