Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
10-25-2004, 15:36 | #1 (permalink) |
No Life Poster Join Date: Sep 2004 Location: in AXE control room Age: 54
Member: 84300 Status: Offline Thanks Meter: 74 | C35 POWER,charging & .... two have same problem : dont charging batt well, start charging with 700mA,on 6 V ,then pumping on Ametre scale from 300-700 mA and after 5 min stop charging. Of course ,bat is not fully loaded .When i try make a call,he says batt empty please recharge. PA is good,and bat data is callibrated, or copied from good one .And with new bat is the same. The third one problem: in stby mode comsumption of batt is cca 200mA !!! and the strange noise From buzz is heard and the buzz is HOT . When i remove buzz the curent is OK, but i changed buzz with good one but the problem is same . WELL this is a problem ! |
10-25-2004, 20:50 | #2 (permalink) |
No Life Poster Join Date: Oct 2001 Location: No route to host. Age: 44
Member: 6772 Status: Offline Thanks Meter: 17 | First of all: C35,M35,S35 = same board. In S35 case IRDA is soldered and LCD is different. [/Quote} two have same problem : dont charging batt well, start charging with 700mA,on 6 V ,then pumping [Quote/] Why do you think software is useless for charging batterys? It means "charging error". 6.0V 300mA MAX! on charging input. In your third case: First try to remove PA and tell us the results. WBR b0ba |
10-26-2004, 07:18 | #3 (permalink) |
Member: 84300 Status: Offline Thanks Meter: 74 | the first prob ( about tipes of phone)- i readed that when 'u put eeprom soft in M series from c series display losee contrast,and c have to much contrast if have m eeprom dump. I removed PA and ant swith but problem is not solved! same consumption of power ( 200mA) in stby mode. |
7210c auto power on & auto charging | ranem_111 | Nokia Hardware & Hardware Repair | 1 | 02-07-2010 12:31 |
D840 power on only when in charge & HW ver:******xx | beneto | Samsung Hardware Repair | 1 | 01-28-2009 10:45 |
MY X2 AUTO CHARGING & AUTO POWER | ORIYOMI | Sagem Hardware Repair Area | 4 | 01-20-2006 13:44 |
gd 92 not power on & not charge with simcard insert | baraka42 | Sagem Hardware Repair Area | 1 | 04-26-2003 22:23 |
c35 after charging power off | NSerN | Siemens Hardware Repair Area | 0 | 06-13-2002 19:20 |
