Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > Siemens Hardware Repair Area
Siemens Hardware Repair Area all about Hardware Repairing you can get if here.
Old 09-24-2005, 15:31   #1 (permalink)
malkjos's Avatar
Member: 13373
Cool A65 C60 deep cut tp REPAIR SOLUTION!!!!
Just see the picture
You dont need to remove the CPU just put wire and carefully rehot the cpu with a lot fluxer.
Yhis solution is tested by me to many times.
works well.
GOOD LUCK
Old 09-24-2005, 15:41   #2 (permalink)
DOUHAL's Avatar
Member: 43036
Sonork: 100.62160
A65 C60 or A65 mc60 ???
The Following User Says Thank You to DOUHAL For This Useful Post:
Old 09-24-2005, 15:43   #3 (permalink)
malkjos's Avatar
Member: 13373
C60 and MC60 its same pin on CPU
good luck
Best regards
Old 09-24-2005, 16:21   #4 (permalink)
digitalmk's Avatar
Member: 33506
good work pedro malkjos
Old 10-05-2005, 22:18   #5 (permalink)
Member: 84824
thanks i like this
Old 10-06-2005, 07:27   #6 (permalink)
Kanwalgee's Avatar
Member: 68392
Sonork: 100.100701
good work br i try it
Old 10-08-2005, 09:22   #7 (permalink)
nofear197979's Avatar
Member: 68311
than you sir very much
Old 10-13-2005, 20:57   #8 (permalink)
sam unlocker's Avatar
Member: 14632
thanks good work we will just to testit
Old 10-15-2005, 05:58   #9 (permalink)
Ashwani Gaur's Avatar
Member: 2822
Can u pls tell us where this wire goes under CPU , i want to know CPU pin no.
thanks
br
Ashwani Gaur
Old 10-18-2005, 08:18   #10 (permalink)
Member: 177298
Unhappy err.. what pin?
yeah, what pin does the jumper wire stick??
i have this now and i cnt seem to power on the phone.
Pls Help!!
Old 10-18-2005, 09:14   #11 (permalink)
malkjos's Avatar
Member: 13373
thanks
br
Ashwani Gaur
This solution is only for OK BUTTON (top left side) and < ^ >
Good luck
Old 10-20-2005, 09:39   #12 (permalink)
ARAB GSM's Avatar
Member: 180675
Sonork: 100.111161 GSM GURU
please can some one send me the picture solution for a70 bad cut repair, i have two a70 phones dead afther cuting test point please help
tanks in advance
Old 10-27-2005, 19:37   #13 (permalink)
Member: 153893
hi to all my sentist for the great job you are doing keep it up.
good luck
Old 11-07-2005, 00:42   #14 (permalink)
Member: 197063
Thanks rolf2
Old 11-07-2005, 01:19   #15 (permalink)
Member: 67104
thanks i need this solution i have one dead mc60 after bad cut ;-)
my way for repairing insert card on cf62 after bad cut tp without removing cpu asmar Siemens Hardware Repair Area 36 09-15-2006 14:34
NEED TP REPAIR FOR A65 and TP A62 denard Siemens Hardware Repair Area 5 03-12-2006 21:22
a55 not powering after deep cut on TP hummy Siemens Hardware Repair Area 0 11-29-2005 02:22
A52 deep cut test point - yes button dead free_gsmx E-Gold Based Phones 9 02-17-2005 17:11
a57 deep cutted Cosmo001 E-Gold Based Phones 0 12-22-2004 18:16
Page generated in 0.59499 seconds with 12 queries
