Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
04-28-2005, 20:06 | #2 (permalink) |
No Life Poster Join Date: Jul 2004 Location: Bandung - West Java, Indonesia Age: 43
Member: 71273 Status: Offline Thanks Meter: 14 | running the FREIA ---->Click the button write flash ----> upload the new flash file ----> choose firmware ----> press power on the phone (use full battery to flash the phone). ----> if flashing finished go to UNLOCKING FUNCTION (replace the battery first) ----> choose direct unlock no map is saved ----> click Use original IMEI sometimes you've got error message "boot file not accepted" it means you should make a test point on the phone before running the flash. Cheers.... |
04-28-2005, 20:25 | #3 (permalink) |
No Life Poster Join Date: Apr 2005 Location: PAKISTAN Age: 45
Member: 133436 Status: Offline Sonork: 100.1577364 Thanks Meter: 191 | Steps to Flash Siemens with Freia First of all phone should be off then and cable is attched with PC & with Mobile then follow the pictures as steps from step1 to step6 take care |
Siemens Flash | YaSSaX | x1x to x45/x50 | 4 | 07-12-2001 14:47 |
siemens flash reader writer | swand | x1x to x45/x50 | 0 | 06-08-2001 12:21 |
Siemens flashing shell by Vygis 1.0 | wazl | x1x to x45/x50 | 6 | 05-12-2001 00:10 |
hi need siemens flashes c35 16.03 and s35 18.03 | ktalangsm | x1x to x45/x50 | 1 | 05-09-2001 07:24 |
what site can found out siemens flash file | Alan Lim | x1x to x45/x50 | 1 | 05-08-2001 17:54 |
