Go Back   GSM-Forum > GSM Mobile Brands -Software Area- > Siemens-Benq > Siemens Hardware Repair Area
Siemens Hardware Repair Area all about Hardware Repairing you can get if here.
Old 10-25-2004, 15:36   #1 (permalink)
Crumarix1's Avatar
Member: 84300
C35 POWER,charging & ....
well, i have 3 c35 ( or m35) how can i know witch type is for real ?
two have same problem : dont charging batt well, start charging with 700mA,on 6 V ,then pumping on Ametre scale from 300-700 mA and after 5 min stop charging. Of course ,bat is not fully loaded .When i try make a call,he says batt empty please recharge. PA is good,and bat data is callibrated, or copied from good one .And with new bat is the same.
The third one problem: in stby mode comsumption of batt is cca 200mA !!!
and the strange noise From buzz is heard and the buzz is HOT .
When i remove buzz the curent is OK, but i changed buzz with good one but the problem is same .
WELL this is a problem !
Digg this Post!Add Post to del.icio.usBookmark Post in TechnoratiFurl this Post!Share on FacebookTwitter
Old 10-25-2004, 20:50   #2 (permalink)
b0ba's Avatar
Member: 6772
First of all: C35,M35,S35 = same board. In S35 case IRDA is soldered and LCD is different.
[/Quote}
[Quote/]
Why do you think software is useless for charging batterys? It means "charging error". 6.0V 300mA MAX! on charging input.
In your third case: First try to remove PA and tell us the results.
WBR
b0ba
Old 10-26-2004, 07:18   #3 (permalink)
Crumarix1's Avatar
Member: 84300
the first prob ( about tipes of phone)- i readed that when 'u put eeprom soft in M series from c series display losee contrast,and c have to much contrast if have m eeprom dump.
I removed PA and ant swith but problem is not solved! same consumption of power ( 200mA) in stby mode.
Old 11-06-2004, 22:36   #4 (permalink)
Member: 56337
- try to fix the battery connector.
- if still try look ELCO ( electronic condensator ) yellow in midle board. change it...
GSMCity - GSM Hosting - 1999-2010
Page generated in 0.05114 seconds with 8 queries
