Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
01-29-2002, 09:42 | #1 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Italy
Member: 7301 Status: Offline Thanks Meter: 0 | C35 Siemens Low signal (3/5) I have low signal strenght on a Siemens C35 , I've already checked antenna, antenna contacts, external antenna connector and TX/RX switch, but the phone still have 3/5 signal <img src="frown.gif" border="0"> Someone knows what other filters and/or components should I check? Where is the IF filter? and the gsm RF filters?? |
01-29-2002, 14:17 | #2 (permalink) |
No Life Poster Join Date: Jul 2001 Location: md Age: 25
Member: 5379 Status: Offline Thanks Meter: 0 | GSM filter located in the upper block (PA block), just look for 2 (two) smaller componen marked epcos, there's also 2 (two) 1800 filter there, larger then the GSM filter and has 2 and 3 holes through it. IF filter is located in the middle block, look for another componen marked EPCOS, located in the middle, beside D5124 and up of LMX2379 maybe u should check the GMS filter driver, marked AMs (4 leg componen) and located near GSM filter |
why input charge 5.6 v but output 3.5 lowing >>>>>3>>1 volt | osom | Nokia Hardware & Hardware Repair | 0 | 10-07-2009 15:02 |
LG KG800 chocolate no signal or low signal | ProGsm2K7 | LG Hardware Repair | 3 | 09-26-2009 12:38 |
new joker for siemen 3.5.6 | rosan | S-Gold Based Phones | 7 | 01-13-2009 04:08 |
Help please C35 Battery low Problem. | hamidtele | x1x to x45/x50 | 7 | 09-25-2003 15:39 |
Siemens C35 Low Signal | Crash2 | x1x to x45/x50 | 1 | 08-07-2001 16:32 |
