Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > Siemens Hardware Repair Area
Siemens Hardware Repair Area all about Hardware Repairing you can get if here.
Old 04-26-2003, 01:13   #1 (permalink)
Member: 14469
Unhappy C45 blank display ?
what the problem is that :?
phone working - i can call and answer, display in good condition(tested at another phone) but display is blank.
I was try to change or resolder capasitors near display connector but problem not soved.
Any ideas ?
Old 04-26-2003, 17:53   #2 (permalink)
genocite's Avatar
Member: 5379
hmmm ... there r about 3 or 4 kinds of c45 displays, according to the manufacturers, hyundai, epson etc, some kinds didn't fit the other kind, try looking for other type of display
Old 04-26-2003, 18:49   #3 (permalink)
microera's Avatar
Member: 4923
I was get two C45 with NO DISPLAY but I cant't repair!
I need help too!
THANKS
Old 04-30-2003, 11:09   #4 (permalink)
Member: 26365
check contrast, eeprom data, resolder cpu,
Old 04-30-2003, 12:08   #5 (permalink)
microera's Avatar
Member: 4923
Load different eeprom from other good C45, then repair with LOG/MAP file (repair check sums)! I think that contrast must be good in this moment, but still no display!!
Only rehot CPU is solution?
WBR
Old 05-08-2003, 15:45   #6 (permalink)
NSerN's Avatar
Member: 8599
I have this problem too!
change SW and LCD didn't help me!
For me it's 100% hardware problem.
How to solve it. somebody know the correct solution.?
Old 05-08-2003, 17:01   #7 (permalink)
Member: 26365
rehot cpu!!!
Old 05-19-2003, 01:44   #8 (permalink)
thecult's Avatar
Member: 9700
rehot c45 cpu????? how much hot do you applyt to mad?? how many time? I thnik it's too easy kill yoru phone
regards
Old 05-20-2003, 01:47   #9 (permalink)
SVH
SVH's Avatar
Member: 9889
just change display, buddy
br
Old 05-20-2003, 22:21   #10 (permalink)
Member: 13981
Sonork: 100.110305
I have repaired few c45 and mt50 with this bug.
try to get working one and check upper part of pcb on not working one, probably you will find broken lines near lcd connector (even if they look for 'good' they are cracked under lacquer).
Good luck!
ps. If you didn't succed then you can send phone to me- I will repair it for free for you
regards!
holden
Old 07-26-2003, 23:48   #11 (permalink)
Member: 35625
hello, thecult was your problem solved if it did post a detailed help message for a novice user. gom3z or anyone else! i wud be thankful if you do it too, write a detailed post explaining procedures, equipment etc.
Thanks.
Shahbaz
nokia 1200 blank display & 1208 blue display solution mobilecitycbk Nokia Hardware & Hardware-Repair Area 5 11-06-2010 13:46
c45 blank screen andrebo x1x to x45/x50 6 07-26-2003 23:44
c45 blank display strange problem thecult Nokia Hardware & Hardware-Repair Area 2 12-16-2002 13:33
C45 blank screen Freeman x1x to x45/x50 17 08-19-2002 00:26
Repairing blank display on 8210......... Abe Nokia Hardware & Hardware-Repair Area 8 04-25-2002 19:08
Page generated in 0.28527 seconds with 11 queries
