Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
11-27-2004, 18:32 | #1 (permalink) |
Junior Member Join Date: Nov 2004 Age: 39
Member: 94229 Status: Offline Thanks Meter: 0 | c55 totally dead please help i am new to that business and i broke my phone i want to cut the test point to write the full flash, but when i looked to the schmeatics on the forum, i think i might have a newest PCB or something i cannot locate the test point. here's the link to the scanned PCB: http://torin.biz/pliki/c55.jpg i would be really gratefull if you could show me witch is that track to cut or wich resistor is it ? thanks |
11-27-2004, 22:16 | #4 (permalink) |
Member: 94229 Status: Offline Thanks Meter: 0 | But when I use Freia i got: COMM_IsBootRunning : bootcode does not seem to be running COMM_LoadBoots : Waiting to power on the phone ... COMM_LoadBoots : phone is not powered on So what to do with it without cutting testpoint ? |
11-28-2004, 16:16 | #6 (permalink) |
No Life Poster Join Date: Oct 2002
Member: 16927 Status: Offline Thanks Meter: 134 | Try change in Freia in Configurations Function Proces Information to "Low" and try enable/disable Com Port Setup "RTS" and "DTR" ant try unlock. Or if dosent work, try: Try unlock, Direct unlock alsao save maps -> Use orginal Imei -> and press shortly few times on/off switch on the phone Or if dosent work, try: This same, but do not click Use orginal imei , just write imei of phone and click OK and again press shortly few times on/off switch on the phone br. fingusio |
11-28-2004, 22:05 | #7 (permalink) |
Member: 94229 Status: Offline Thanks Meter: 0 | Code: COMM_LoadBoots : selected phone family is 8 COMM_IsBootRunning : bootcode does not seem to be running COMM_LoadBoots : Waiting to power on the phone ... COMM_LoadBoots : phone is not powered on |
11-29-2004, 00:01 | #10 (permalink) |
Member: 94229 Status: Offline Thanks Meter: 0 | The cable is 100% ok becouse before telephone had applied few patches java copied into flex etc. But im interested how to test with DES when my phone is down ? I will rehot that IC tommorow orning, so i will write what are the resulus. Will the simple hair dryer be enough ? |
11-29-2004, 02:18 | #13 (permalink) | |
Freak Poster Join Date: Dec 2003 Location: Nicaragua
Member: 45752 Status: Offline Thanks Meter: 19 | Quote:
Use botton repair of Siemens Service ToolBox http://www.sst-gsm.nm.ru/ToolboxFree.zip This worked with me, Good Luck | |
11-29-2004, 11:36 | #15 (permalink) |
Member: 16927 Status: Offline Thanks Meter: 134 | Some Siemens from series x35, x45, x55 have this problem. I dont know why, never on this forum i dont see thread about this. Maybe your connector in phone was repaired, and someone dont repair so well;] check connector maybe? br. fingusio |
C55 totally dead...help me! | Fireice | E-Gold Based Phones | 11 | 02-01-2004 15:28 |
C55 totally Dead plz help | x4ce | E-Gold Based Phones | 8 | 12-27-2003 03:45 |
6210 totally dead, please help | weiss77 | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 7 | 12-12-2003 13:19 |
Dead C55 after unlock - please help | vopigsm | E-Gold Based Phones | 6 | 06-23-2003 08:13 |
c55 is dead,please help | gonzo | E-Gold Based Phones | 0 | 04-06-2003 11:31 |
