Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
03-01-2005, 17:17 | #1 (permalink) |
Freak Poster Join Date: Feb 2004 Location: ITALY Age: 55
Member: 55672 Status: Offline Thanks Meter: 9 | C60 Dead I also have the ' box ' martech II with test adapter v.2, someone can help me to resolve this problem software on these telephones, if of problem software been drawn, if you can also give me some suggestions hardware. Thank's Repair68 |
03-01-2005, 17:33 | #2 (permalink) |
Freak Poster Join Date: May 2001 Location: bulgaria
Member: 4610 Status: Offline Thanks Meter: 3 | HI REPAIR68 create log and map and write this map to phone using freia 15 all must be ok.if not sucsess - write good eeprom and flash and make log and map and write map =100% SUCSEED. Best regards from Bulgaria |
03-07-2005, 17:54 | #3 (permalink) |
No Life Poster Join Date: Jul 2004 Location: BANDA ACEH INDONESIA
Member: 74519 Status: Offline Thanks Meter: 79 | I need it I have same problem, my c60 is dead now after flash, eeprom imei corrupt, I need eeprom and firmare for C60, any body can help me? regards |
03-27-2005, 11:32 | #4 (permalink) | |
No Life Poster Join Date: May 2003 Location: yopougon(cote d'ivoire)
Member: 28334 Status: Offline Thanks Meter: 4 | Quote:
use freia 10 or higher : 1.write boot repair file 2mb 2.write fubu 14mb 3.unlock 4.write imei if needed | |
06-01-2005, 18:28 | #7 (permalink) | |
No Life Poster Join Date: Mar 2001 Location: Croatia Age: 45
Member: 3508 Status: Offline Thanks Meter: 71 | Quote:
Read phone info - with tespoints You will get flash ID, so you need full flash from readed ID Full flash your phone (Update firmware + Write eprom) Then go to IMEI repair And now your phone should work again! BR | |
C60 Dead after cut the track Help | xareme | E-Gold Based Phones | 2 | 02-01-2004 19:38 |
c60 dead | bernardo | E-Gold Based Phones | 0 | 01-31-2004 18:59 |
after upload the map c60 dead | alex_SW | E-Gold Based Phones | 13 | 01-28-2004 14:01 |
C60 Dead!! Help Pls | Deframat | E-Gold Based Phones | 2 | 01-05-2004 11:02 |
C60 dead | zoki | E-Gold Based Phones | 18 | 01-04-2004 02:06 |
