Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
11-24-2005, 01:02 | #1 (permalink) |
No Life Poster Join Date: Jan 2000 Location: NL Age: 55
Member: 847 Status: Offline Thanks Meter: 36 | SX1 contact supplier Phone was dead, reflow flash ics, then made a mistake by flashing sl65 flash into it. Reflashed sx1 8mb flash into it and with winswup i flashed the rest. Formatted the phone but error keeps the same. software or hardware? thanks Sjakie |
11-24-2005, 20:38 | #3 (permalink) |
Member: 847 Status: Offline Thanks Meter: 36 | Hi, thanks for rply Thats what i did, first 8mb by sst, then swup. And normally this does the job , but this time still error. maybe bad ram? regards Sjakie |
11-26-2005, 14:51 | #5 (permalink) |
Member: 847 Status: Offline Thanks Meter: 36 | Hi, at first it was dead.. Then reflow than i got some signs off life, right after i flashed sl65 35mb.with sst Then corrected with 8mb sx1 and then swup..all. Result was phone turns on ok, but error message. Mostly format phone rpairs that, but not in this case. regards Sjakie |
11-27-2005, 21:15 | #7 (permalink) |
No Life Poster Join Date: Aug 2004 Location: Pakistan < Karachi Age: 41
Member: 76456 Status: Offline Sonork: 100.1678368 Thanks Meter: 60 | i had tried last 20 time not B ok after flash did only hand format pcs ok other wise gardware *# power for formating |
12-16-2005, 14:32 | #9 (permalink) | |
Registered User Join Date: Dec 2004 Age: 49
Member: 95674 Status: Offline Thanks Meter: 7 | sx1 dead Quote:
12-16-2005, 14:53 | #10 (permalink) | |
Member: 95674 Status: Offline Thanks Meter: 7 | Quote:
12-16-2005, 14:53 | #11 (permalink) | |
03-22-2006, 17:32 | #14 (permalink) |
Junior Member Join Date: Feb 2005 Age: 46
Member: 112284 Status: Offline Thanks Meter: 1 | sjakie,maybe your sx1 is ok,but you must use original battery to power on it,if you use power supplier ,you will see "contact retailer" message. to farmat sx1,you can power down it ,then press "*" and "#" key,then press power key to power on,and release ,you can see formatting progress bar is going on. |
S5230 sim does not support please contact suppliers | linjie | Z3X-Team Products | 1 | 07-31-2009 19:03 |
gd87 Unlock Blocked , Contact Supplier | Aamir_Zia | Panasonic | 1 | 12-16-2004 23:49 |
Gd87 Unlock Blocked Contact Supplier | Colin | Panasonic | 10 | 06-15-2003 14:34 |
gd87 contact supplier | flexasist | Panasonic | 2 | 06-03-2003 18:09 |
contact supplier | lampin | Motorola Old Legacy (EMMI) | 1 | 11-16-2000 07:19 |
