Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > Siemens Hardware Repair Area
Siemens Hardware Repair Area all about Hardware Repairing you can get if here.
Old 10-12-2006, 22:36   #1 (permalink)
llcoolr's Avatar
Member: 53408
Sonork: 100.1593951
Thumbs up CF110 sim problem solution
aftre many testes i found this and it's working 1000000000000%
poste results
The Following 2 Users Say Thank You to llcoolr For This Useful Post:
Old 10-12-2006, 23:33   #2 (permalink)
Tetouan Gsm's Avatar
Member: 190492
Sonork: 100.01010100
Old solution but okis Nice work ...
Old 10-12-2006, 23:35   #3 (permalink)
zolla's Avatar
Member: 175544
tested and worrk perfectly tankssssssssss
Old 10-13-2006, 00:45   #4 (permalink)
tostefo's Avatar
Member: 77941
.........same like nokia sim emi filter you can also change it withaut any problem with nokia filter..........
wbr
Old 11-13-2006, 16:52   #5 (permalink)
Member: 67562
Sonork: none
But there are 2 resistors. Any1 knows what resistance?
I damaged thisone closer metal cover.
Old 11-14-2006, 09:26   #6 (permalink)
irfaN_vu's Avatar
Member: 130244
Sonork: 100.1609062
am just gonna try this sol after that i will post comments....
Old 11-14-2006, 10:22   #7 (permalink)
Member: 67562
Sonork: none
OK. I can answear for my question. Resistor closer to metal cover is not needed. Phone working without it.
Old 11-15-2006, 12:52   #8 (permalink)
Member: 374198
poste results
how do you make connections if your solder pads lift off? I had A1 and A3 (two orange pads in diagram) come off in s65 and want to connect them. Has anyone ever had that happen in CF110?
Old 11-15-2006, 13:30   #9 (permalink)
Fantoz's Avatar
Member: 172678
Old 03-16-2007, 13:39   #10 (permalink)
Member: 61438
poste results
So , I now the post is old , but im very big thank's for good Job!!!
Sorry for my English
Old 03-26-2007, 10:18   #11 (permalink)
ATIEFUOR-GSM's Avatar
Member: 132856
nice work keep it up
Old 04-06-2007, 15:16   #12 (permalink)
Member: 374033
cf110 ic sim
ic from nokia work 100% (3100...6100 etc) tested and work
Old 04-06-2007, 15:47   #13 (permalink)
Member: 221490
Old 04-06-2007, 16:30   #14 (permalink)
Member: 447104
cf110 insert simcard solution
other solution here tested ok
Old 05-26-2007, 22:33   #15 (permalink)
Member: 242985
TESTED AND WORKED 100%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%%% THANK´S
***In Active Sim problem Solution***? caremobiles SETool2 4 03-10-2010 11:46
new sim problem solution for 2600 1100 .... nizoudj Nokia Hardware & Hardware-Repair Area 1 05-19-2008 13:21
CF110 sim reader problem llcoolr E-Gold Based Phones 1 10-15-2006 21:52
Page generated in 0.35293 seconds with 12 queries
