Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
12-05-2005, 12:02 | #1 (permalink) |
Crazy Poster Join Date: Feb 2003 Location: North Spain
Member: 22472 Status: Offline Thanks Meter: 1 | CF62 bad TP cut Solution? Before making the jumpers posted by spulber001 here http://forum.gsmhosting.com/vbb/atta...6&d=1133449446 I`ve maked the measurement between the different points, and there is continuity!!!! how is it possible, and the phone say "Insert Sim Card"...... I measure between: Sim card 6 - R1614 = piiiiiiiiiii Sim card 1 - R1605 = piiiiiiiiiii Sim card 2 - pin 4 of V1605 = piiiiiiii Any idea? B.R. PaPiTo |
12-05-2005, 23:45 | #3 (permalink) |
Member: 22472 Status: Offline Thanks Meter: 1 | Thanks for you reply Chris, but for me is not possible remove the cpu. The question is why the phone have link between the points marked by spulber001 and the phone say "insert sim card". When I make the cut, is no really a cut, i have made a scratch. Is possible other reason for the phone say "insert sim card" ?? b.r. PaPiTo |
12-06-2005, 20:05 | #4 (permalink) |
No Life Poster Join Date: Oct 2003 Location: Germany Age: 37
Member: 41076 Status: Offline Thanks Meter: 53 | Because the connection was aborted between the resistors and CPU. And you check the connection between Sim connector and Resistor Ways are CPU-->Resistor-->Sim Reader Yes, your "scratch" is the fault reason |
M55 bad TP cut solution? | sloper | Siemens Hardware Repair Area | 5 | 12-26-2005 09:08 |
cf62 bad cut now inser sim solution 100& | eeprom_flash | S-Gold Based Phones | 4 | 08-06-2005 02:56 |
how to repair siemens cf62 bad tp cut | crisrad | S-Gold Based Phones | 8 | 01-08-2005 21:10 |
A Fix found for Cf62 TP cut | ednacell | S-Gold Based Phones | 0 | 11-07-2004 04:57 |
A Fix found for Cf62 TP cut | ednacell | S-Gold Based Phones | 0 | 11-07-2004 04:55 |
