Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
02-19-2007, 15:13 | #1 (permalink) |
Freak Poster Join Date: Jul 2004 Location: JATT LABLE Age: 43
Member: 73479 Status: Offline Sonork: 100.1581683 Thanks Meter: 55 | Cf62 Not Charging Does any one have any solutions siemens cf62 not charging when i in sert charger it shows its charging but it dose not charge you can see the charging arow moving showing charging please help urgent Thanks. |
02-19-2007, 18:15 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
Mesure the batery. It is need to have more 4 Volts if is charged. If not... try to charge the battery. Maybe this is your problem. Br, dagos | |
02-20-2007, 08:53 | #3 (permalink) |
Member: 73479 Status: Offline Sonork: 100.1581683 Thanks Meter: 55 | thanks Hi, The phone is perfect it comes on batt voltage is ok ......... it shows charging but dose not charge like it dose put charge in the batt |
02-20-2007, 18:20 | #5 (permalink) | |
In this case try to change double diode V1400. Many times this is the problem... br, dagos Last edited by dagos; 06-15-2008 at 15:40. | |
11-28-2007, 12:17 | #14 (permalink) |
No Life Poster Join Date: Jun 2007 Location: dhaka,bangladesh
Member: 528679 Status: Offline Thanks Meter: 268 | CF 62 show charge backup nathing hi , if dont get ic then make jumper picture like....... Sopnil |
The Following User Says Thank You to sopnil For This Useful Post: |
3660 not charging help plz | dj.comcell | WD2 & APE (Symbian Phones) | 0 | 03-29-2010 14:08 |
CF62 - not complet charging and power off | dagos | S-Gold Based Phones | 0 | 04-10-2007 17:07 |
Cf62 Does Not Charge | kwamena | Siemens Hardware Repair Area | 0 | 09-05-2006 13:13 |
CF62 not charging... :(( | melsoft | Siemens Hardware Repair Area | 0 | 06-05-2006 09:00 |
Hello anybody, my Nokia-3210 is not charging it is showing not charging | varma raj | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 05-25-2003 11:27 |
