Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
09-05-2005, 00:41 | #1 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | Cf62 TP without SIM NOT PRESENT :) how-to few days ago i fixed few phucked Cf62 phones which Showed INSERT SIM CARD, with deep-cutted TestPoint also, i had few pcs to unlock, so i checked out new TP cutting place, which dont phuck up the SIM card ways. use sharp cutting tool, and AGAIN : Dont cut too deep !!! (I cutted little deeper one phone just to test, it was OK, no Insert. SIM ) (it's more secure than old TP, but be carefull again !) b.r. Alexandar. |
09-05-2005, 03:46 | #3 (permalink) | |
Banned Join Date: Aug 2004 Location: Gsm Unlockers Awareness Report
Member: 76978 Status: Offline Thanks Meter: 15 | Quote:
BR | |
09-05-2005, 17:41 | #5 (permalink) |
No Life Poster Join Date: Sep 2003 Location: Dubai
Member: 39022 Status: Offline Sonork: 1575244 Thanks Meter: 94 | lol good not show any new thing so u cut near or far , result is same the point is this just cut lightly if not sucess than again cut lightly not cut much deep |
09-06-2005, 10:06 | #6 (permalink) | |
Banned Join Date: Jul 2005 Location: Philippines Age: 53
Member: 161739 Status: Offline Sonork: 100.1584054 Thanks Meter: 3,338 | Quote:
<<<<<< 10000 x thanks ur solution is 100% ok tested todat 3 phones ver. 95. sanders li | |
09-06-2005, 14:21 | #10 (permalink) |
Cheater -Don't Deal with him- Join Date: Nov 2002 Location: Tunisia Age: 45
Member: 18022 Status: Offline Sonork: 1574868 Thanks Meter: 192 | i have tried putting flux on TP and making a bridge to sim card reader pin 6 and it worked but after just 1 min i get card error? br |
09-06-2005, 15:25 | #11 (permalink) |
No Life Poster Join Date: Oct 2002 Location: Ukraine,Simferopol Age: 48
Member: 16251 Status: Offline Thanks Meter: 38 | open your eyes! tomorrow i found all that i need just use SEARCH button in forum! i enter CF62 in search window and on first page of result i found solution!(need to restore 2 track under testpoint ! now phone is alive |
09-06-2005, 15:36 | #12 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,778 | @Rise, you're wrong, because sim line is going just under old TP cutting place, and when you cut on place i showed, you can not damage sim lines, be sure about that. i guarantee that @InfoGSM i succesfully repaired few pcs with liquid silver b.r. Alexandar. |
09-06-2005, 16:02 | #13 (permalink) |
Member: 39022 Status: Offline Sonork: 1575244 Thanks Meter: 94 | @Brka i again tell u that nothing is new which u try to explain 1 side u show that ur testpoint is safe and other side u also show that cut testpoint light if ur testpoint is better and save than y u show in 1st thread that "Dont cut too deep " it mean that "this testpoint same as old testpoint" |
09-06-2005, 18:46 | #14 (permalink) |
Insane Poster Join Date: Aug 2005
Member: 170122 Status: Offline Thanks Meter: 14 | Same testpoint The testpoint are the same. If you use a microscope and a sharp tool there is no risk of any damage. I got one phone damaged by a deep cut by somebody that tried to unlock it I managed to fix the sim problem with some flux and soldering under the microscope. It worked ok. |
mw3026 SIM not present with SIM inside | adypet1 | Infineon C16X M51 & ARM7 M52 BASED | 19 | 05-09-2004 16:53 |
Sagem MW 936E Sim not present with or without sim card | florinmar | Infineon C16X M51 & ARM7 M52 BASED | 7 | 11-04-2002 15:43 |
MV930 D2 sim not present | hansis | Infineon C16X M51 & ARM7 M52 BASED | 4 | 07-03-2002 20:08 |
MC930 sim not present | insidebga | Infineon C16X M51 & ARM7 M52 BASED | 0 | 06-09-2001 17:50 |
mc 939 "SIM NOT PRESENT" | cris | Infineon C16X M51 & ARM7 M52 BASED | 0 | 01-05-2001 17:50 |
