Go Back   GSM-Forum > GSM Mobile / Tablets Brands -Software Area- > Various > Siemens-Benq > Siemens Hardware Repair Area
Siemens Hardware Repair Area all about Hardware Repairing you can get if here.
Old 08-02-2006, 15:16   #1 (permalink)
stylius's Avatar
Member: 51989
Sonork: 1575109
Question Daes exist way how to chek cpu ram flash without remove from PCB?
Daes anybody know diagram for Cx65, C65 and other siemens phone?
Old 08-05-2006, 11:39   #2 (permalink)
Member: 135968
not really
long time ago -the JTAG interface was accessable - to execute a Boundary-Scan test - to test connections between different boundaryscanable parts. (E-GOLD, GAIM, Halfrate-CoPro, DSP) Also ram and Flash connections were tested tricky, becouse they have no Boundaryscan interface. They generated 0x00 , 0xFF and 0x55 on Data / Adressbus- this was readout via the boundaryscan interface. (in production on error message was "ram Adress 5555 has not value 0x55").
But JTAG is not really accessable anymore.
JTAG pins are : TDI (TestDataInput)- TDO(utput) - TMS(TestModeSelect) -
TCK (TestClock) - MON1 (Monitoring1) - MON2 (always named "TESTPOINT").
Note:
Its long time Ago that i've repaired phones... there is no guarantee.
greets from sunny Duisburg
Old 08-06-2006, 22:15   #3 (permalink)
stylius's Avatar
Member: 51989
Sonork: 1575109
Thanks for you answer... But how to check cpu? without removing it from PCB?
Old 08-07-2006, 04:50   #4 (permalink)
Member: 212944
only one problem of cpu i know for this phones - not working keyboard!
other problems are the broken wires of PCB under the CPU...
i think there is no problem to desolder flash and look under it... no reballing need to solder it back `cause of HUGE solder balls
Old 08-07-2006, 11:15   #5 (permalink)
stylius's Avatar
Member: 51989
Sonork: 1575109
Yes, i agree with you... But sometimes i get dead phone, and dont know is cpu good or not.
Old 08-07-2006, 11:40   #6 (permalink)
Member: 25852
if CPU is dead no power consumtion ! you can test it by power supply !
Old 08-12-2006, 07:46   #7 (permalink)
Member: 135968
thats wrong, there ist also power-consuption if the phone is dead or cpu is dead , the value can tell you something about the failure.
I've written some essays about it in this forum - use search button.
greets from rainy cold Duisburg
How to unlock L6, U6, V360... without remove shield ? gsm_unlock2 Smart-Clip 52 02-17-2011 07:12
how to rebuild imei if s/n removed from back cover? Kashif Khan UST Pro II 9 06-14-2009 14:57
best way - how to remove glued IC cel_phon Nokia Hardware & Hardware-Repair Area 0 06-03-2009 05:28
how to chek in 3g iphone that its 2.0,2.01 or 2.02 .:M@ster:. iPhone ,iPod & iPad (Apple Inc. Products) 1 08-30-2008 11:04
how to chek the version of lg ku311 .:M@ster:. FuriouS TeaM Products 1 12-21-2006 19:07
Page generated in 0.62529 seconds with 11 queries
