Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
03-23-2003, 11:01 | #1 (permalink) |
Freak Poster Join Date: Nov 2001 Location: Here Age: 44
Member: 7676 Status: Offline Thanks Meter: 4 | a35 signal problem i try (with the same problem ) with full software , some time it`s work , but this phone not work there`s no water dameged , is there any way to fix this problem , i have many phone ? Thanks |
03-26-2003, 17:45 | #9 (permalink) |
Freak Poster Join Date: Feb 2003 Location: Tasmania Age: 55
Member: 21408 Status: Offline Thanks Meter: 0 | Try to cal 112, if you have '' Call Ended '' , 99% is a PA problem. Check very carefuly if , after change with a new one, the solderings. After all, if you use another PA ( second hand ) it could be broken. there are some cracks that you can only view with a strong eyeglass. Good lock ! |
repair signal problem use best signal generator | gsmbotol | Nokia Hardware & Hardware Repair | 7 | 05-24-2004 09:16 |
a35 signal problem | joe locks | Siemens Hardware Repair Area | 1 | 07-12-2002 10:33 |
a35 ear problem... | xchris | Siemens Hardware Repair Area | 1 | 03-24-2002 09:01 |
A35-36 Signal Problem.. | F C | Siemens Hardware Repair Area | 1 | 03-20-2002 22:57 |
Siemens A35 v25 problem | mansi | x1x to x45/x50 | 5 | 01-19-2002 00:11 |
