Siemens Hardware Repair Area all about Hardware Repairing you can get if here. |
04-13-2008, 11:01 | #1 (permalink) |
Freak Poster Join Date: Jun 2006 Location: Tunisia
Member: 296895 Status: Offline Thanks Meter: 33 | help with el-71 nothing other so i can't start my phone ( ok not worked ) is there any solution motherboard is so clean : no water , no damage , nothing ... please help and thanks. |
04-13-2008, 11:49 | #2 (permalink) | |
No Life Poster Join Date: Dec 2006
Member: 416908 Status: Offline Thanks Meter: 398 | Quote:
dagos | |
04-15-2008, 17:17 | #10 (permalink) | |
Best regards, dagos | |
04-17-2008, 12:41 | #11 (permalink) |
Member: 296895 Status: Offline Thanks Meter: 33 | i try your solution , " 71 (block)" , phonr boot without asking for aircraft and defrag software but nothing , i will try to flash it but i don't known where i can get a full flash for el71 and loader because i think popua can't flash it. can you help me please, and thank you very much for helping me. |
04-17-2008, 19:46 | #12 (permalink) | |
for fullflash file, go to http://eh.student.utwente.nl/~landy/...r=Repair_FuBu/ user: mobile password: elibom and download "EL71_Fullflash El71 v45 pl lang(cleen).exe" , run it (extract .bin file) and flash with the X65 flasher software (search on this forum for this - I suggest to use 2103 version) . You need to use testpoint or BsReader midlet. To use X65 flasher you have the option to save "config.ini file" from papua (click on "x65flasher.ini from the "Codes" menu - after SKey and BKey calculation and save this file on the X65flasher folder) or directly calculate SKey and BKey with X65flasher - testpoint or java midlet procedure. Search on this forum how to calculate this keys on the X65 phones (EL71 is X86 series, but not is important...). dagos | |
i want helzzzzz pleazzz with EL 71 | gsm-mochoa | Siemens Hardware Repair Area | 1 | 08-25-2007 11:23 |
el 71 dead need help | klodi | Martech CLIP / Box / Key | 2 | 07-21-2007 10:56 |
siemens el 71 problem to open | a2b2t | Siemens Hardware Repair Area | 0 | 11-05-2006 15:24 |
EL 71 big problem | mirolic | SIEM Service Tools | 0 | 11-03-2006 21:02 |
siemens EL-71 | gsm3005 | S-Gold Based Phones | 1 | 07-07-2006 19:03 |
