Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > Siemens-Benq > Siemens Hardware Repair Area
Siemens Hardware Repair Area all about Hardware Repairing you can get if here.
Old 08-05-2005, 09:53   #1 (permalink)
Member: 32284
Thanks Meter: 4
Weird problem with A60..
Hi all!
Realy weird..phone came to me with buzzz problem...I tried to unlock..but boot file not accepteb..ok..I cut test point..boot accepted..I flashed it..than unlock..everything ok...but when I power phone up..no data on display..phone accepts sim card..I can make calls also receive calls...but no data on display...I read around..but nothing..and cant remember to saw a post after cut no data on display...I also reheated CPU...no luck..any ideas good apreciated..
Thanks and regards!
sergo_zmeia
Old 08-05-2005, 09:55   #2 (permalink)
BB-gsm's Avatar
Member: 75765
Thanks Meter: 722
Hello !
Display is blue or white right ?
Look for x55 contrast tool by ACiD and set contrast manually, it`s quite easy to manage !
Regards,
BeQuA
Old 08-05-2005, 10:03   #3 (permalink)
Member: 32284
Thanks Meter: 4
Hi!
Display is blue...contrast tool didnt helped me..I guess its a eeprom problem..Ill try a different flash now..report after a minutes..
Regards!
sergo_zmeia
PS:BBgsm, my c65 works after reheat CPU...
Old 08-05-2005, 10:35   #4 (permalink)
BB-gsm's Avatar
Member: 75765
Thanks Meter: 722
Regards!
sergo_zmeia
No, no ... It`s 100% contrast problem, do not use SST contrast tool, use written by ACiD ...
No need any other eeprom, coz this tool writes/repairs exactly the eeprom data to get normal LCD
P.S. Ur A60 will work well also soon
Old 08-05-2005, 10:41   #5 (permalink)
Member: 32284
Thanks Meter: 4
Hi!
Im using ACID contrast tool..no luck..now Im flashing...report after minutes..
Regards!
sergo_zmeia
Old 08-10-2005, 03:50   #6 (permalink)
Member: 62315
my friend try this
1-flash phone with full flash 14 mb.
2-make log from phone.
3-make map from log.
4-write map to phone.
5-unlock phone .
all ok my friend
Weird problem with dead N73 ft.servicing Nokia Base Band 5 ( BB-5 ) 5 12-09-2006 14:41
WEird problem with KZF .:GSM International:. HWK 5 11-24-2006 07:09
weird problem with nokia 1100.. SicilianBoy Nokia Digital Core Technology 4 ( DCT-4 ) 1 01-05-2006 00:36
weird problem with gd55 Bomber Panasonic 2 10-22-2003 14:27
WeiRD PrObLeM WiTh 8250 ryumahon Nokia Hardware & Hardware Repair 2 11-15-2002 16:51
Page generated in 0.25893 seconds with 9 queries
